Numpty can't select phone(bluetooth) as source
hairgoneJohn
Unread post by hairgoneJohn »
Hi
I've just bought a 2012 DS3 1.6Hdi for my daughter and am having a senior moment....and she's having a junior moment! :rofl2:
The radio does not have a model no. visible but it has a large monochrome screen (not touch) and is marked bluetooth. Both I and my daughter can pair our phones (one android, one Apple) to the radio and the radio shows bluetooth connected.
However we cannot figure out how to play phone music through the radio. If the source button is pressed it toggles between radio and external (is this the wired connection above the 12v socket?) but bluetooth does not show.
Please can anyone help.
x 8106
Re: Numpty can't select phone(blutooth) as source
I'm sure one of the members will be able to confirm this but I have a vague feeling that it may not be as easy as it should be. There were some models where the bluetooth only worked for hands free and you had to use the aux input to play music but I don't know if that applies to yours i'm afraid! :)
x 1942
Unread post by Paul-R »
I concur with Mick. Some Bluetooth models are phone only. Have a look at the photos here and se if you can identify your unit viewforum.php?f=44 Note particularly the difference between the eMyWay / RT6 / RNEG2 / WIPNAV+ unit and the MyWay / RNEG / WIPNAV unit.
A photograph of the unit in situ may also help.
hairgoneJohn
Thanks. I have the Myway unit, which I now see doesn't allow audio streaming.
How very French ! 🤣🤣
LeRoy KinCaid
x 5
Re: Numpty can't select phone(bluetooth) as source
Unread post by LeRoy KinCaid »
I have the same in a 2011 C3 Picasso, although Bluetooth it doesn't play music from the phone, does your phone have a headphone socket? If so plug into the external socket, if phone doesn't have headphones socket you can get a Bluetooth unit to plug into car external socket then pair that to phone.
Richard_C
(Donor 2026)
x 227
Unread post by Richard_C »
LeRoy KinCaid wrote: 03 Nov 2025, 11:19 I have the same in a 2011 C3 Picasso, although Bluetooth it doesn't play music from the phone, does your phone have a headphone socket? If so plug into the external socket, if phone doesn't have headphones socket you can get a Bluetooth unit to plug into car external socket then pair that to phone.
If the phones have USB C, you can get a simple and inexpensive adapter from USBC to 3.5mm stereo jack socket, so it works just like a headphone socket. Something like this (there are many, many others)
https://www.amazon.co.uk/Headphone-Digi ... rce=1&th=1
Richard_C
hairgoneJohn
Thanks for that. A good idea,
