Hi
I have Peugeot 308 1.6Hdi, 5-speed manual gearbox ,VIN: VF3**************[VIN obfuscated, can be read by forum staff].
How much gear oil if I want to change it?
Also do I top up the new gear oil via the side under the wheel arch or from the top of the gear box under the battery?
Gear oil change
TopCar
Gear oil change
- x 1940
Re: Gear oil change
Assuming you have a 6-speed manual gearbox:
This is what a gearbox with fins looks like. This should be like yours
And this is a gearbox without fins.
There is no side filler on these gearboxes, you have to put a measured amount of oil in through the breather which is on the top of the gearbox.
| ML6C | Gearbox casing without fins | Gearbox casing with fins |
| Drain and refill | 2.6 litres | 1.9 litres |
| After overhaul | 2.8 litres | 2.2 litres |
TopCar
Re: Gear oil change
My car is 5 gear manual, year 2009
