405 temp guage fault
trafic9
having got our peugeot 405 dt, we have found out it is has a fault with the temp sender unit.we have changed the one where the top hose from the readiator leads from.i have located another one that is situated on the radiator.can anyone tell me if this is one too.its situated on the right hand side of the radiator as you look in the engine bay
TheWorker
woodhead722
The one on the radiator is possibly the fan switch to cool the radiator. Check by disconnecting, and if I remember rightly there will be 3 contacts on as I believe the fan has 2 speeds for cooling (on my '92 diesel)
If you short curcuit the leads the fan will switch on.
I would IMAGINE if it is another sender for temp scale then the scale needle will go to max.
woodhead722
trafic9
