Which oil is correct
Guldzinski73
I have a 2015 mkii Citroen dispatch van 1.6hdi which is the correct oil is total quartz 0w30 low saps suitable
- x 8132
Re: Which oil is correct
I only use Shell oils and get all the info I need from this site: https://www.shell.co.uk/fuels-oils-and- ... diL2VuLWdi
Guldzinski73
Is 0w30!low saps oil correct for a 2015 1.6hdi Citroen dispatch deisel van I live in the uk
Huskyxantia
- x 918
Ive a 1.6hdi engine in 2 dif cars i used 5w 30. 0 seems a bit to thin . It's all about running temperatures 5w 30 is a good choice for the uk
Husky.
- x 1940
If it's not a BlueHdi engine then both 5W30 (B71 2290) and 0W30 (B71 2312) are authorised. If it's a 1.6 BlueHdi then it's only 0W30 (B71 2312) that's authorised.
Those B71 xxxx specifications are important. If that's not on the can then avoid.
Mihael_M
- x 37
In 2024, Stellantis introduced the 5W-30 engine oil specification, FPW9.55535/03, following a recall. This new oil is now mandatory for a wide range of Stellantis engines. Previously, MPM 05000PC 0W-30 or 05000PC-FE 0W-20 was recommended for these engines, but due to the recall, the recommendation has changed to MPM 05000ST 5W-30 with the FPW9.55535/03 specification.
Stellantis has recently expanded this requirement: the 5W-30 oil with specification FPW9.55535/03 is now mandatory for all 1.2-litre PureTech EB2xxxx engines (excluding EB2LTxx) , for 2.2-litre DW10Fx engines and the 1.5 BlueHDi (DV5R) .
Please note that oil service tags or service books may still show outdated recommendations.
- x 1940
But the 1.6 BluHDi engines(and non BlueHDi 1.6 engines) aren't mentioned so remain as I posted.
Mihael_M
- x 37
Yes Paul this change is not valid for 1.6 BlueHdi. My mistake , sorry . But for the 1.6 BlueHDi, the Stellantis recommendation from July 2024 that you mentioned is still valid, which is 0W30 Oil B71 2312.
viewtopic.php?p=768074#p768074
