What to do if the Citroën C5 Aircross has excessive engine oil consumption?
xiaowuge
What product can be added to address excessive engine oil consumption in the Citroën C5 Aircross by removing carbon deposits and thereby alleviating the issue?
- x 8141
Re: What to do if the Citroën C5 Aircross has excessive engine oil consumption?
Are you sure you don't have a leak?
xiaowuge
??????1.6T????????????????????????????????????????????
Onlinemyglaren
- x 5674
Please post in Englishxiaowuge wrote: 24 Oct 2025, 20:56 ??????1.6T????????????????????????????????????????????
The Citroën C4 in China is notorious for burning oil, particularly with the 1.6T engine. I'd like to ask our international forum members: what additives do you use to reduce oil consumption without resorting to engine overhaul?
xiaowuge
Engine burnout in Citroën's 1.6T models is a common issue in China, so I would like to ask you, overseas netizens, what additives you use to reduce burnout without disassembling the engine.
lcwin
- x 9
This engine have a design problem with the oil control piston ring. The 200hp version rings is better. Try using piston ring additive that you put in the engine oil . Follow the instruction on how to use. If the clogging is not serious it will help otherwise you can try looking for stronger additive oil or replace the piston rings and seals. Always use good 5w-30 oil and change oil more frequently especially for town driving .
Sloppysod
- x 397
I'm interested in the term "16T engine", mainly because my car was built in China and has the 1.6 163 puretech engine that seems to be robust.
Do you have the exact engine type number something like EP6FADTXD?
Info taken from https://en.wikipedia.org/wiki/Prince_engine#EP6FDT
Cheers
Cheers
Stu
