turbo setting
frankieyeha
turbo setting
put new turbo and wastegate now getting P2562 not getting enough turbo charge on the torque app the boost clock says .29 is this right or should be higher on tickover.
- x 8100
Re: turbo setting
I'd check through the induction piping for air leaks, tightening up any suspect joints and then run another diagnostic.
frankieyeha
Re: turbo setting
Is that the pipe that comes of the air filter box.
- x 1486
Re: turbo setting
What fault did you have before? Is there actually a sensor on the turbo? Have you reconnected the vac pipe to the turbo actuator and is it working?
frankieyeha
Re: turbo setting
The first code was p2563 changed the waste gate now it's this code.
- x 8100
Re: turbo setting
You may get some ideas from this site: https://iamcarhacker.com/fix-p2562/
frankieyeha
Re: turbo setting
on my machine under live data in the list 0ne is control module voltage it says 0 volts in red i checked another car with the same engine his says 12.5 volts can some1 tell me what the control module is thanks in advance.
- x 1486
Re: turbo setting
There's a boost control solenoid somewhere, possibly down the back of the engine. Follow the vac hose from the turbo, checking it for splits as you go.
frankieyeha
Re: turbo setting
Yes it's at the front eight of the engine replaced it with a brand new one and checked the hoses
frankieyeha
Re: turbo setting
I've just noticed the PCB is leaking oil that might be one of my problems.
