Hi
My car stopped on the way last, and after few minutes I was enable to start it again. After I connected diagn tool, I got a lot of errors with ecu/park brake/egr. I checked few forums/topics and is it EGR which need to be cleaned/changed?
C4 citroen 1.6hdi 2008
C4 1.6 hdi a lot of errors
Kacper2709
Reason: Images corrected
- x 8165
Re: C4 1.6 hdi a lot of errors
I would try running an EGR cleaner through the system, check the battery and charging, reset the BSI following this procedure, then run another global test and see what you get.
Huskyxantia
- x 928
This car needs a good old fashioned de coke
Husky.
