Display stopped working
cncjeff1
I have a 2016 Berlingo, VIN VF7**************[VIN obfuscated, can be read by forum staff]. Suddenly, the display was limited to what is shown in the pictures. The radio won't work. None of the diagnostics work. Occasionally, when I first turn on the ignition, the display will show "Initialize pressure" but does not give me access. Anyone have any ideas?
- x 8126
Re: Display stopped working
I would suggest you try a BSI reset to have a blank sheet to start from and then see what you have. You will probably need to scan the car with Diagbox to determine what is going on. BSI reset procedure: viewtopic.php?p=601679#p601679
cncjeff1
Just wanted to say Thank You to Mick. The BSI reset solved the problem. Can I buy you a "coffee"?
- x 8126
The thought is appreciated and I'm glad the reset helped. You can always make donations to the Forum using the button top left but please don't feel obliged to. We just do our best to help!!
