Diesel or Oil Leak?
joaocpereira
x 3
Diesel or Oil Leak?
Unread post by joaocpereira »
Hello
I look at the motor today and saw this liquid around this area… is that oil or diesel? Any guess where look for a leak?
x 1943
Re: Diesel or Oil Leak?
Unread post by Paul-R »
Probably engine oil. I had similar pools of oil and it came from the cam cover to cylinder head joint. I had it fixed at the same time I had the timing belt, tensioners, etc changed.
You don't say what engine you have fitted but it's a not uncommon fault with the 1.6 BlueHdi diesel engine.
joaocpereira
x 3
Paul-R wrote: 13 Oct 2025, 13:38 Probably engine oil. I had similar pools of oil and it came from the cam cover to cylinder head joint. I had it fixed at the same time I had the timing belt, tensioners, etc changed.
It's an 1.6 HDI.
Thank you for the info.
