FUEL PUMP IS OK??? Is that noise normal? DS3 HDI
joaocpereira
x 3
Unread post by joaocpereira »
Hello guys,
Is tha noise normal when I turn the key? It's look like to be the fuelpump but is normal to be so laught?
[video][/video]
x 5672
Re: Is that NOISE NORMAL? DS3 HDI
Sounds like the fuel pump priming.
joaocpereira
x 3
myglaren wrote: 12 Oct 2025, 11:44 Sounds like the fuel pump priming.
Yes but, if is, is normall to be so loud?
x 5672
Rather hard to judge as I had to run the sound through a stereo amp and speakers to be ale to hear it.
Mine sounded similar on my C5s but happened as the car was unlocked or a door opened. Only for a few seconds but unlikely to be an identical system.
joaocpereira
x 3
myglaren wrote: 12 Oct 2025, 13:10 Rather hard to judge as I had to run the sound through a stereo amp and speakers to be ale to hear it.
Thank for your answer.
Ofc the pum should do some noise but I find the noise to loud. But maybe it's me cause I never had a french car and maybe this is normal :) Hope it is :)
joaocpereira
x 3
Any guesses? People with 1.6 HDI please
x 1938
Re: FUEL PUMP IS OK??? Is that noise normal? DS3 HDI
Unread post by Paul-R »
On my 1.6 BlueHdi there is no electric fuel pump so there's no pump noise.
@joaocpereira If you you have a fuel primer bulb in the engine bay like the one in the picture then you do not not have an electric pump in the fuel tank either. So it cannot be the source of your noise.
However
If the 1.6 is also a BlueHdi then the noise may be the pump for the Adblue priming itself.
joaocpereira
x 3
Paul-R wrote: 16 Oct 2025, 19:34 On my 1.6 BlueHdi there is no electric fuel pump so there's no pump noise.
However
Yeah I don't have that bulb.
But is normal for the adblue do this noise? Also sometimes like a 'squirt'? :lol:
