Hello guys,
Is tha noise normal when I turn the key? It's look like to be the fuelpump but is normal to be so laught?
[video][/video]
FUEL PUMP IS OK??? Is that noise normal? DS3 HDI
joaocpereira
- x 3
- x 5674
Re: Is that NOISE NORMAL? DS3 HDI
Sounds like the fuel pump priming.
joaocpereira
- x 3
Yes but, if is, is normall to be so loud?
- x 5674
Rather hard to judge as I had to run the sound through a stereo amp and speakers to be ale to hear it.
Mine sounded similar on my C5s but happened as the car was unlocked or a door opened. Only for a few seconds but unlikely to be an identical system.
joaocpereira
- x 3
Thank for your answer.myglaren wrote: 12 Oct 2025, 13:10 Rather hard to judge as I had to run the sound through a stereo amp and speakers to be ale to hear it.
Ofc the pum should do some noise but I find the noise to loud. But maybe it's me cause I never had a french car and maybe this is normal
joaocpereira
- x 3
Any guesses? People with 1.6 HDI please
- x 1941
Re: FUEL PUMP IS OK??? Is that noise normal? DS3 HDI
On my 1.6 BlueHdi there is no electric fuel pump so there's no pump noise.
@joaocpereira If you you have a fuel primer bulb in the engine bay like the one in the picture then you do not not have an electric pump in the fuel tank either. So it cannot be the source of your noise.
However
If the 1.6 is also a BlueHdi then the noise may be the pump for the Adblue priming itself.
However
joaocpereira
- x 3
Yeah I don't have that bulb.Paul-R wrote: 16 Oct 2025, 19:34 On my 1.6 BlueHdi there is no electric fuel pump so there's no pump noise.
However
But is normal for the adblue do this noise? Also sometimes like a 'squirt'?
