2003 mk1 Citroen c5 auto gearbox refill
notinserviceuk
x 5
Unread post by notinserviceuk »
i looked is there a vid or certain way to reill or check gear box oil level please
x 8145
Re: 2003 mk1 Citroen c5 auto gearbox refill
Have a look at this site for info on how to change the oil.: https://howtomendit.com/answers?id=373553
x 1056
Unread post by wheeler »
AL4 or 4HP20 gearbox?
Cant remember the 4HP20 off hand but the AL4 you need to have a diagnostic tool connected that can read the oil temperature as it has to be checked when it is 60 degrees C.
You also need to add oil to check the level.
Confirm which gearbox you have & will get the exact procedure.
