Hello
I'm a mechanic and I have a workshop in Portugal.
I really need someone's help.
I've been working on a van for 2 months and I can't solve the problem!
Citroen C4 Gran Picasso B78 1.6 HDi 2013
I arrived at the workshop with the ABS light on and the electric parking brake not working!
I ran diagnostics with DiagBox, and the ABS/ESP/PARK BRAKE module isn't communicating.
I tested the wiring and it's ok.
I tested the CAN lines and it's ok.
I tested the fuses and it's ok.
I replaced the ABS module, but it's still the same.
I tested it with another BSI from another car, and it's not communicating.
If anyone can help me, I'd be very grateful! I'm desperate.
Best regards!
Citroen c4 Picasso 2 b78 ABS Not comunication PLEASE HELP
MMSGARAGE
Huskyxantia
- x 901
Re: Citroen c4 Picasso 2 b78 ABS Not comunication PLEASE HELP
Have you changed the reluctor rings ? If it has any
Husky.
Huskyxantia
- x 901
Also anything on this circuit that has a plug checked them ? Corrosion on the pins can cause this, is it your car , was was it like before this fault happened ? Double check all the looms , wiggle them aswell , get ohms reading to all the abs sensors as sometimes poor signals can be causes of this fault, hope this might help
Husky.
Huskyxantia
- x 901
Also the brake switch can be faulty can cause this issue too
Husky.
MMSGARAGE
Good morning! I didn't replace any of the phonic wheels. The car isn't mine, it belongs to a customer. It was like this instantly. I checked all the connectors, no corrosion. I'm going to check the brake switch, but if it were that part, wouldn't it malfunction? I can't access diagnostics with the ABS module.
Huskyxantia
- x 901
ive heard and seen myself with a car i once owned my reverse lights didn't work nor the brake lights , I swapped the switch for a new one my problem was solved
Husky.
Huskyxantia
- x 901
It's like these lives all seem to be near the same area and when one thing goes it messes other things up too.
Husky.
MMSGARAGE
Solved...
New abs module fault, replace for new one and repair wire brake rear eletectric and every thing is right.
