Citroen c4 Picasso 2 b78 ABS Not comunication PLEASE HELP
MMSGARAGE
Unread post by MMSGARAGE »
Hello
I'm a mechanic and I have a workshop in Portugal.
I really need someone's help.
I've been working on a van for 2 months and I can't solve the problem!
Citroen C4 Gran Picasso B78 1.6 HDi 2013
I arrived at the workshop with the ABS light on and the electric parking brake not working!
I ran diagnostics with DiagBox, and the ABS/ESP/PARK BRAKE module isn't communicating.
I tested the wiring and it's ok.
I tested the CAN lines and it's ok.
I tested the fuses and it's ok.
I replaced the ABS module, but it's still the same.
I tested it with another BSI from another car, and it's not communicating.
If anyone can help me, I'd be very grateful! I'm desperate.
Best regards!
Huskyxantia
x 757
Re: Citroen c4 Picasso 2 b78 ABS Not comunication PLEASE HELP
Unread post by Huskyxantia »
Have you changed the reluctor rings ? If it has any
:-D
Huskyxantia
x 757
Also anything on this circuit that has a plug checked them ? Corrosion on the pins can cause this, is it your car , was was it like before this fault happened ? Double check all the looms , wiggle them aswell , get ohms reading to all the abs sensors as sometimes poor signals can be causes of this fault, hope this might help
:-D
Huskyxantia
x 757
Also the brake switch can be faulty can cause this issue too
:-D
MMSGARAGE
Good morning! I didn't replace any of the phonic wheels. The car isn't mine, it belongs to a customer. It was like this instantly. I checked all the connectors, no corrosion. I'm going to check the brake switch, but if it were that part, wouldn't it malfunction? I can't access diagnostics with the ABS module.
Huskyxantia
x 757
ive heard and seen myself with a car i once owned my reverse lights didn't work nor the brake lights , I swapped the switch for a new one my problem was solved
:-D
Huskyxantia
x 757
It's like these lives all seem to be near the same area and when one thing goes it messes other things up too.
:-D
MMSGARAGE
Solved...
New abs module fault, replace for new one and repair wire brake rear eletectric and every thing is right.
