owl wrote: 15 Oct 2025, 21:14
May I ask you please check this vin out for trim specs.? There is a misunderstanding between me and seller. He says this is shine pack, I say not it is written lounge. Since there is no lounge pack
VR7**************[VIN obfuscated, can be read by forum staff]
Thank you in advance
Vehicle characteristics
C5 AIRCROSS (C84) 5-DOOR CROSS OVER 1.5 BlueHDi 130 (DV5RC Euro 6.2) STT TYPE 8-SPEED AUTOMATIC GEARBOX
Vehicle family C5 AIRCROSS (C84)
AS/RP N° 15787 CJ 2 0065
Warranty Start Date 11/03/2020
Engine serial number 10 Q4DL 0093903
OPB 00DZ
BER e2*2007/46*0642*03
P4A 9835917499
General information
PRODUCT TYPE PASSENGER CAR
COMMERCIAL MARQUE/COMPONENT TYPE CITROEN
VEHICLE FAMILY C5 AIRCROSS (C84)
SILHOUETTE 5-DOOR CROSS OVER
TRIM LEVEL UPPER MEDIUM
ENGINE DV5RC 96KW 1.5L DIESEL
TRANSMISSION STT TYPE 8-SPEED AUTOMATIC GEARBOX
PAINT TYPE PAINTED METALLIC EXT TRIM TYPE
BODY COLOUR EDZ - EMERALD CRYSTAL PAINT
INTERIOR TRIM TYPE NAPPA LEATHER "4H"
UPHOLSTERY COLOUR "FE"
GEARBOX (CHARACTERISTICS) ATNG8
DEFINITION TO FOLLOW INITIALE RANGE
ENGINE (TYPE) DV TYPE ENGINE
ROOF (EXT. ASPECT) BODY COLOUR ROOF
OTHER BADGE, " MISC. " WITHOUT FULLER BADGE
Fuel supply-Engine
FAN 2-SPEED FAN 140W AERO COMPACT DYNAMIC FLAP
DRIVE TRAIN INTERNAL COMBUSTION DRIVE TRAIN
TANK FILTER RESERVOIR FILTER INTERIOR
STOP AND START WITH STOP AND START STARTER
FUEL SUPPLY DIRECT EXCHANGER TURBO INJECTION
DIESEL FILTER WATER DETECTOR WITHOUT DIESEL FILTER WATER DETECTOR
FUEL DIESEL GRADE DA/DE/DE+
EMISSIONS STANDARD (ENGINE) EURO 6.2 ENGINE EMISSION CONTROL
EXHAUST STANDARD EXHAUST
SPEED SENSOR SIGNAL FRONT WHEEL SENSOR NON-SIGN RR SIGNED
CAPACITY 1500 CM3
FUEL TANK NON-PRESSURISED FUEL TANK WITH LOCATING TAB
COOLING MOTOR RADIATOR EP28 28DM2 BRAZED ALUMINIUM
CRANKCASE GAS CIRCUIT HEATING WITH HEATER CASING GAS CIRCUIT
POWER VARIATION (ENGINE) ENGINE POWER 96 KW 300 NM
SPECIAL POWER TRAIN SOUND WITHOUT POWER TRAIN ACOUSTICS
EOBD SELF-DIAGNOSIS SYSTEM WITH "OBD" AUTO-DIAGNOSTICS
DEVICE (ANTIPOLLUTION) EXHAUST GAS RECYCING "EGR" + EXCHANGER
VEHICLE TECHNICAL DEPOLLUTION EURO 6.2 VEHICLE TECHNICAL EMISSION CONTROL
PARTICLE FILTER WITH PARTICLE EMISSION FILTER
Gearbox Transmission
GEARBOX TYPE ATN8 TYPE GEARBOX
FINAL DRIVE RATIO FINAL DRIVE RATIO 15 X 58
WHEEL STYLE 19-INCH SAW ALLOY WHEEL
CLUTCH WITHOUT CLUTCH
RIM/TYRE SIZE 19 INCH TYRE FIT
TYRE (SIZE, TYPE) 205/55 R19 97V TYRE
WHEEL (TYPE) ALLOY WHEEL ASSEMBLY 1
INFLATION PRESSURE LOSS INDICATOR INDIRECT DETECTION OF UNDER-INFLATION WITH LOCATION
Suspension-Steering-Brakes
BRAKE ASSOCIATED VARIANT ESP BOSCH 9.1
STEERING (OPERATION) LOW POWER DOUBLE PINION ELECTRIC POWER STEERING
PEDAL BRACKET (TYPE) SIMPLE STANDARD PEDAL BRACKET
REAR ANTI-ROLL BAR REAR ANTI-ROLL BAR STIFFNESS 30000 NM/RAD
STEERING COLUMN RETRACTABLE STEERING COLUMN
FRONT ANTI-ROLL BAR FR ANTI-ROLL BAR STIFFNESS 30000 NM/RAD
BRAKE TYPE VENTILATED FRONT DISCS/REAR DISCS
STEERING WHEEL ANGLE WITH STEERING ANGLE SENSOR
SUSPENSION NORMAL SUSPENSION
SUSPENSION (ARCHITECTURE TYPE) METAL SUSPENSION
DYNAMIC STABILITY CONTROL SYSTEM ELECTRONIC STABILITY PROGRAM
Body fittings
HANDS FREE ACCESS AND STARTING FRONT ACCESS + BOOT + HANDS FREE STARTING
TOWBAR WITHOUT TOWBAR
HORNS HORNS-HARMONY
SIDE MOULDINGS (TYPE) ALUMINIUM COLOUR SIDE PROTECTORS
SIDE MOULDINGS (DIMENSION) WITHOUT SIDE PROTECTOR, WITH CHROME SILL
WHEEL EMBELLISHER (STYLE) WITHOUT WHEEL TRIM
EXHAUST TAILPIPE WITHOUT EXHAUST TAIL PIPE
UNDERBODY SHIELD WITHOUT PROTECTION UNDER BODY
ADDITIONAL SHIELD (UNDER ENGINE) W/O ENGINE UNDERSHELDING
EXT. LOAD RETENTION RING (ATTACHMENT) WITHOUT DETACHABLE EXTERIOR LASHING RING
EXT. REARVIEW MIRROR COMP. FUNCTION DRIVER ELEC FOLDING+PASSENGER+DIODE+REVERSE +MEMORY
ENGINE BAY SOUNDPROOFING SOUNDPROOFING FOR BULKHEAD + WHEELARCH + POWER TRAIN
WINDSCREEN GLASS (TYPE) STANDARD WINDSCREEN GLASS
WINDSCREEN WIPER FRONT WIPER BLADE WITH RAIN SENSOR
ROOF GLASS WITHOUT ROOF WINDOW
BUMPER BODY COLOUR FRONT BUMPER+GLOSS BLACK GRILLE/BODY COLOUR REAR BUMPER + TAILPIPE
NUMBER PLATE WITHOUT LICENCE PLATE
LUGGAGE RACK MOUNTING WITH ROOF BARS
FRONT FOGLAMP FOG LAMPS WITH CORNERING LIGHT
PANORAMIC VISUAL AID WITH REAR PANORAMIC VISUAL ASSISTANCE VISIO PARK1
SPARE WHEEL SPACE-SAVING SPARE WHEEL
EXTERIOR ACCESSORIES BODY COLOUR EXTERIOR HANDLE
EXT. REAR VIEW MIRROR (DRIVER SIDE RADIUS) CURVED EXTERIOR MIRROR GLASS
GLASS (APPEARANCE) TINTED + DARK-TINTED WINDOW GLASS
WINDOW (TYPE) ACOUSTIC LAMINATED WINDSCREEN + TOUGHENED REAR GLASS
Interior fittings
SEATING ASSOCIATED VARIANT VARIANT ASSOCIATED WITH HIGH SEAT POSITION
AUDIO PACK AUXILIARY SOCKET 2 USB PORTS
TELEMATIC UNIT INDEPENDENT TELEMATIC UNIT 3S
ANTI-THEFT ALARM WITHOUT THEFT PROTECTION ALARM
FRONT HEAD RESTRAINT 4-WAY ADJUSTABLE FRONT HEAD RESTRAINT
BLIND SPOT DETECTION ACTIVE BLIND SPOT MONITORING
REAR SEATBELT 2 PYRO RETRACTORD+ SEATBELT FASTENED TELL-TALE
CLIMATE (AMBIENT TEMP) COLD COUNTRIES
AIR CONDITIONING WITH AUTO RECIRCULATION HEATER MATRIX
CHILD LOCK MANUAL REAR CHILD LOCK
SPEED GRADUATIONS SPEED GRADUATION IN KM/H
GEAR SELECTOR RAISED GEAR LEVER AT THE FLOOR + AT THE STEERING WHEEL
CONSOLE UPPER CONSOLE + STORAGE COMPARTMENT
DRIVING POSITION LEFT-HAND DRIVE
ADDITIONAL HEATING WITHOUT ADDITIONNAL HEATING
MIRROR LINK WITH MIRROR LINK
MISC. INT. LAMPS LC FR/RR LEDS WITHOUT AMB LED WITH AMB LGT
INSTRUMENT PANEL (CHARACTERISTICS) DIGITAL INSTRUMENT PANEL 29 WARNING LAMPS
DOOR TRIM GLOSS BLACK DECOR DOOR TRIM
CHILD SEAT ANCHORING POINTS WITH CHILD SEAT MOUNTING WITH ISO FR AND RR
PROTECTIVE COVER WITHOUT PROTECTIVE BATTERY COVER
POLLEN FILTER WITH POLLEN FILTER + ACTIVATED CARBON
DRIVER SEAT CONTROL DRIVER’S SEAT MEMORY CONTROL
FRONT PASSENGER SEAT CONTROL MANUAL FRONT PASSENGER SEAT CONTROL
DRIVER SEAT ADJUSTMENT DRIVER’S SEAT TILTING BACK ELECPNE LUMBAR SUPPORT+MEMO
FRONT PASSENGER SEAT ADJUSTMENT ADJUSTMENT FRONT PASSENGER SEAT CUSHION RECLINING SEAT BACK
FRONT SEAT ARMREST CENTRAL ARMREST FLOCKED + PVC
SATELLITE NAVIGATION SYSTEM WITH NAVIGATION SYSTEM COLOUR SCREEN
HEADLAMP BULBS LED BULB
TRAFFIC INFORMATION READER PREVENTION+TRAJECTORY CENTRING LPA
DISPLAY DGT8C SCREEN DISPLAY
COURTESY MIRROR DRIVER’S + PASSENGER’S CONCEALABLE WITH LIGHT
CUSHION PADDING PADDING WITH PASSENGER DETECTION PAD
OIL GAUGE W/O OIL LEVEL INDICATOR
HEATING ELEMENT DRIVER + R1 PASSENGER HEATED SEAT
FRONT LATERAL AIRBAG FR CHEST/PELVIS SIDE AIRBAG+CURTAIN AIRBAG
FOOTWELL LIGHTING DRIVER + FR PASSENGER FOOTWELL LIGHTING
REAR PASSENGER PROTECTION W/O RR PASSENGER PROTECTION
EQUIPMENT PACK W/O EQUIPMENT PACK
AIRBAG DEACTIVATION MANUAL AIRBAG DEACTIVATION
HEADLAMP HEIGHT ADJUSTER AUTOMATIC HEADLAMP ADJUSTMENT
WIFI WITH WIFI
RADIO RECEIVER DIGITAL CONNECTED NAVIGATION
REFRIGERATION AUTOMATIC AIR CONDITIONING
CRUISE CONTROL SPEED LIMITER ACC STOP AND GO REGULATOR
INTERIOR REAR VIEW MIRROR ELECTROCHROMATIC DAY-NIGHT INTERIOR MIRROR
CARPET COVER BLACK MAT CONTRAST SURROUND+LASER ENGRAVING
LOAD SPACE STORAGE RETRACTABLE FLOOR STORAGE COMPARTMENT
REAR SEAT PADDING REAR PASSENGER DETECTION WITH PAD
TUNER RADIO DUAL RADIO TUNER
OBSTACLE DETECTION SYSTEM FRONT-REAR RADAR OBSTACLE SENSOR
EQUALISER AMPLIFIER WITHOUT EQUALISER AMPLIFIER
RADIO FREQUENCY WESTERN EUROPE RADIO FREQUENCY
LOCKING CONTROL NORMAL + AUTOMATIC LOCKING
STEERING WHEEL FULL GRAIN LEATHER FULL 3-SPOKE STEERING WHEEL
Electrical
LIGHTING OF LAMPS AUTOMATIC SWITCHING ON OF THE LIGHTS+AUTOMATIC SWITCHING
ALTERNATOR ALTERNATOR CLASS 18 180 AMP
HORNS HORNS-HARMONY
BATTERY BATTERY L3 760 70AH EFR 760 EN EF
STARTER MOTOR STTD STARTER
CEN. LOCKING REM CONTROL FREQUENCY 433.92 MHZ SUPER HETERODYNE
BATTERY CHARGER WITHOUT ON-BOARD CHARGER
MULTIPLEXING R3 ECO ELECTRICAL ARCHITECTURE
ELECTRIC VEHICLE CHARGING PLUG WITHOUT VEHICLE LOAD RECOGNITION
BATTERY CHARGE MEASUREMENT WITH BATTERY CHARGE MEASUREMENT
Component manufacturers
Miscellaneous
SPECIAL SPECIFICATION SOCIETE (OVSA)
MODIF. DURING MODEL YEAR WITHOUT MINOR MODIFICATIONS
CONDENSER (SPECIFICATIONS) CONDENSER 23,5DM2 THICKNESS 12
ATMOSPHERIC CONDITIONS NORMAL ATMOSPHERE
VIN PLATE EUROPEAN UNION CONSTRUCTOR’S PLATE + NRE
LABEL WITHOUT LABEL
AIR CONDITIONING PIPES IHX TECHNOLOGY AIR CONDITIONING PIPES
RADIO HEADPHONE SOCKET DOUBLE ACCESSORY SOCKET
TRAFFIC SIDE DRIVING ON THE RIGHT-HAND SIDE
SIDE IMPACTS REINFORCED SIDE IMPACT PROTECTORS
SET OF KEYS SET OF BADGE KEYS + BACK-UP KEY
DOOR SEAL FRONT DOOR FRONT SEAL
REFRIGERANT AIRCON FLUID 1234 YF
EMERGENCY EQUIPMENT W/O HELP EQUIPMENT
SURFACE CONDITIONS GOOD TERRAIN
SPEED MONITORING WITHOUT SPEED CHECK
SLAVE CONTROL UNIT BSI + COM 2008 + POLY SOUND
EMERGENCY WARNING TRIANGLE WITHOUT WARNING TRIANGLE
