I need information about trim level from VIN
edinbabic
Unread post by edinbabic »
Hello :)
I'm thinking of buying a Peugeot 508 from 2014, I've got the VIN and I would like to get some information about the car (trim level, options, etc).
VIN NUMBER: VF3**************[VIN obfuscated, can be read by forum staff]
Thank you very much!
x 8119
Re: I need information about trim level from VIN
Unfortunately the forum doesn't have access to the databases at the moment but a hopefully a member with their own access will see your post and be able to help you out :)
owl
x 15
Unread post by owl »
https://carsbat.io/
Check this website out. It shows some detailed information. You should enter vin and click search
edinbabic
I tried all available, including CarVertical, with no success... If someone can check it, I would be grateful!
x 1056
Unread post by wheeler »
Vehicle characteristics
Vehicle family 508
AS/RP N° 13850 CJ 1 0236
Warranty Start Date 21/11/2014
Engine serial number 10 DYZL 4012818
BER e2*2007/46*0080*24
P4A 9802301499
General information
PRODUCT TYPE PASSENGER CAR
COMMERCIAL MARQUE/COMPONENT TYPE PEUGEOT
VEHICLE FAMILY 508
SILHOUETTE 4 DOOR SALOON
TRIM LEVEL HIGH MEDIUM PLUS
ENGINE DIESEL DW10FC FAP 132KW
TRANSMISSION AUTO GBOX 6-SPEED STT
PAINT TYPE METALLIC LACQUER
BODY COLOUR KGN - BOURRASQUE PAINT
INTERIOR TRIM TYPE LEATHER "CLAUDIA" Q1
UPHOLSTERY COLOUR "FD"
GEARBOX (CHARACTERISTICS) BVA AM6C
DEFINITION TO FOLLOW MID-LIFE
ENGINE (TYPE) EW/DW
OTHER BADGE, " MISC. " BLUE HDI
STEERING POWER STEERING
SPEEDOMETER DRIVE WITHOUT SPEEDOMETER RATIO
Fuel supply-Engine
FUEL SUPPLY INJECTION SUPPLY
DIESEL FILTER WATER DETECTOR WITHOUT DIESEL FILTER WATER DETECTOR
FUEL DIESEL GRADE DA/DE/DE+
EMISSIONS STANDARD (ENGINE) EURO 6.1 ENGINE EMISSION CONTROL
EXHAUST LONGITUDINAL REAR SILENCER
ENGINE (TYPE) EW/DW
CAPACITY 2000 CM3
CATALYTIC CONVERTER LOWER CATALYTIC CONVERTER 500 PPM 70 GR
OIL COOLER MNTG EXCHANGER ON ENG & G/BOX
FUEL TANK FUEL TANK WITH LOCATING TAB
OPTIMISATION OF VEHICLE’S CONSUMPTION OPTIMISED FUEL CONSUMPTION
CRANKCASE GAS CIRCUIT HEATING W/O HEATER CASING GAS CIRCUIT
POWER VARIATION (ENGINE) POWER 133 KW 400 NM
EOBD SELF-DIAGNOSIS SYSTEM "EOBD" SELF-DIAGNOSIS
DEVICE (ANTIPOLLUTION) "EGR" EXHAUST GAS RECYCLING
VEHICLE TECHNICAL DEPOLLUTION EURO 6.1 VEHICLE TECHNICAL EMISSION CONTROL
PARTICLE FILTER WITH PARTICLE EMISSION FILTER
FAN 1 DUAL-SPEED ELECTRONIC FAN 140W
INJECTION ASSOCIATED VARIANT MOUNTING DELPHI
DRIVE TRAIN INTERNAL COMBUSTION DRIVE TRAIN
TANK FILTER RESERVOIR FILTER INTERIOR
THROTTLE HOUSING (ENGINE INLET AIR CIRCUIT) MOTORISED THROTTLE BODY (ENG AIR INTAKE)
STOP AND START WITH STOP AND START
Gearbox Transmission
FINAL DRIVE RATIO CP 15 X 53
WHEEL STYLE WHEEL LED ZEP 17"
CLUTCH WITHOUT CLUTCH
SEAL, WHEEL END WHEEL-SIDE SEAL RZ20
SEAL, DIFFERENTIAL END JB3T AXLE-SIDE SEAL
DIFFERENTIAL (GEARBOX) DIFFERENTIAL 86
RIM/TYRE SIZE 17 INCH TYRE FITMENT
TYRE (SIZE, TYPE) 215/55 R17 98W REINFORCED TYRE
DRIVING WHEELS 2 DRIVEN WHEELS
WHEEL (TYPE) ALLOY 9 WHEEL FITTING
INFLATION PRESSURE LOSS INDICATOR LOSS OF INFLATION PRESSURE INDICATOR EU STANDARD 64.02
GEARBOX TYPE AM6 AUTO GBOX NORM EURO6
Suspension-Steering-Brakes
REAR ANTI-ROLL BAR REAR ANTI-ROLL BAR DIAM 20
STEERING COLUMN MANUALLY ADJUSTED STEERING COLUMN
FRONT ANTI-ROLL BAR FRONT ANTI-ROLL BAR DIAM 23
SUSPENSION NORMAL SUSPENSION
ACTIVE SUSPENSION WITHOUT VARIABLE SUSPENSION
SUSPENSION (ARCHITECTURE TYPE) METAL SUSPENSION
DYNAMIC STABILITY CONTROL SYSTEM WITH ESC SYSTEM
BRAKE ASSOCIATED VARIANT 8 1 BOSCH ESP
STEERING (OPERATION) ASSISTED ELECTROHYDRAULIC STEERING
Body fittings
TOWBAR WITHOUT TOWBAR
AERIAL AERIAL + GPS
PAYLOAD LOAD CAPACITY 815 KG
FINISHER (SELF-ADHESIVE) BLACK FRONT/REAR SIDE + REAR DOOR WINDOW TRIM
SIDE MOULDINGS (TYPE) WITHOUT LATERAL PROTECTORS
SIDE MOULDINGS (DIMENSION) WITHOUT BODY SILL PROTECTORS
WHEEL EMBELLISHER (STYLE) WITHOUT WHEEL CAP
SILL ILLUMINATION LAMP FRONT SILL LIGHTING LIGHT
ADDITIONAL SHIELD (UNDER ENGINE) W/O ENGINE UNDERSHELDING
EXT. LOAD RETENTION RING (ATTACHMENT) WITHOUT DETACHABLE EXTERIOR LASHING RING
EXT. REARVIEW MIRROR COMP. FUNCTION ELECTRIC FOLDING EXT REAR VIEW MIRROR NO MEMORY
ENGINE BAY SOUNDPROOFING BONNET SOUNDPROOFING
WINDSCREEN WIPER FRONT WIPER BLADE WITH RAIN SENSOR
REAR SCREEN WIPER W/O REAR SCREEN WASH WIPE
HEADLAMP WIPER W/O HEADLAMP WIPER
FRONT PANEL BLANK WITH AIR INTAKE MODULE FR FACE CLOSER
ROOF GLASS WITHOUT ROOF WINDOW
REAR TAILGATE GLASS FIXED TAILGATE WINDOW
BUMPER STANDARD BODY COLOUR FR/RR BUMPERS + CHROME GRILLE
MUDFLAP WITHOUT REAR MUDGUARD
NUMBER PLATE WITHOUT LICENCE PLATE
LUGGAGE RACK WITHOUT ROOF BARS
FRONT FOGLAMP FRONT FOG LIGHTS
PANORAMIC VISUAL AID WITHOUT PANORAMIC VISUAL AID
SPARE WHEEL WITHOUT SPARE WHEEL
EXTERIOR ACCESSORIES EXTERIOR HANDLE AND SLIDE TRIM, CHROME
EXT. REAR VIEW MIRROR (DRIVER SIDE RADIUS) CURVED EXTERIOR MIRROR GLASS
SUN ROOF FIXED ROOF
BUMPER TRIM BUMPER WITH CHROME INSERT
GLASS (APPEARANCE) WINDOW TINTED
WINDOW (TYPE) ACOUSTIC LAMINATED WINDSCREEN+TOUGHENED RR SCREEN
HANDS FREE ACCESS AND STARTING WITH ACCES AND HANDSFREE STARTING
Interior fittings
ANTI-THEFT ALARM WITHOUT THEFT PROTECTION ALARM
REAR SEAT SEPARATE FOLD BACK BENCH SEAT
BLIND SPOT DETECTION WITH BLIND SPOT MONITORING
REAR SEAT ARMREST WITH REAR SEAT ARMREST
REAR SEATBELT 3 REEL 3 PT REAR SAFE BELT + UNBUKLED WARNING
FRONT SEATBELT DOUBLE PYROTECHNIC SEAT BELT WITH ALARM
CLIMATE (AMBIENT TEMP) TEMPERATE COUNTRIES
CHILD LOCK ELECTRIC REAR CHILD LOCK
SPEED GRADUATIONS SPEED GRADUATION IN KM/H
GEAR SELECTOR GEAR CONTROL AT THE STEERING WHEEL
DRIVING POSITION LEFT-HAND DRIVE
ADDITIONAL HEATING WITHOUT ADDITIONNAL HEATING
DASHBOARD EQUIPMENT SIMULATED WOOD DECOR
MISC. INT. LAMPS FR + RR LED MAP READER
LOAD SPACE TRIM BOOT CARPET + CARPET SIDES
INSTRUMENT PANEL (CHARACTERISTICS) GRADUATION 260 KM/H 160 M/H COLOUR MATRIX
DOOR TRIM PVC DECOR
LOUDSPEAKER 4 HP FRONT (2 TW + FR) + 4 HP REAR
RADIO CONTROLS STANDARD AUDIO SYSTEM REMOTE CONTROL
SCREENING (BLIND, SIDE SUNBLIND, SUNROOF) MANUAL REAR BLIND
FRONT PASSENGER SEAT HEIGHT CONTROL PASSENGER BOOSTER PARALLEL + FRONT ADJUSTMENT
DRIVER SEAT CONTROL DRIVERS FRT SEAT ELEC CONTROL
FRONT PASSENGER SEAT CONTROL PASSENGER FRT SEAT ELEC CNTRL
DRIVER SEAT ADJUSTMENT DRIVER’S LUMBAR ADJUSTMENT
FRONT PASSENGER SEAT ADJUSTMENT PASSENGER LUMBAR ADJUSTMENT
FRONT SEAT ARMREST (OPERATION) FRONT ARMREST MANUAL
COMPACT DISC WITHOUT COMPACT DISC
SATELLITE NAVIGATION SYSTEM WITH NAVIGATION SYSTEM COLOUR SCREEN
HEADLAMP BULBS LED BULB
REAR WINDOW LIFT SEQENT CONTR RR WINDOW LIFTER
PASSENGER’S WINDOW LIFT SEQUEN CONTROL PASSENG FRONT WINDOW LIFTER
DISPLAY TOUCH DIGITAL SCREEN DISPLAY
COURTESY MIRROR DRIVER’S + PASSENGER’S CONCEALABLE WITH LIGHT
OIL GAUGE OIL TEMP + LEVEL INDICATOR
FITTING REAR HEAD RESTRAINT MOUNT 3 REAR HEAD-REST
HEATING ELEMENT HEATED SEAT
FRONT LATERAL AIRBAG THORAX SIDE + CURTAIN AIRBAG
FOOTWELL LIGHTING DRIVER + FR+RR PASS FOOTWELL LIGHTING
REAR PASSENGER PROTECTION W/O RR PASSENGER PROTECTION
AIRBAG DEACTIVATION MANUAL AIRBAG DEACTIVATION
HEADLAMP HEIGHT ADJUSTER AUTOMATIC HEADLAMP ADJUSTMENT
DIRECTIONAL HEADLAMP WITHOUT DIRECTIONAL LIGHTS
RADIO RECEIVER SMEG ANALOGUE RADIO RECEIVER
REFRIGERATION AUTOMATIC AIR CONDITIONING
CRUISE CONTROL REGULATOR AND SPEED LIMIT
DRIVER’S SEAT HEIGHT CONTROL ELECTRIC CONTRL DRIVERS HEIGHT ADJ
INTERIOR REAR VIEW MIRROR ELECTROCHROMATIC DAY-NIGHT INTERIOR MIRROR
AIR CON./TEMPERATURE REGULATION FOUR-ZONE AUTOMATIC AIR CONDITIONING
CARPET COVER TRAMONTANE MATS
LOAD SPACE STORAGE W/O BOOT TIDY
TUNER RADIO TRI RADIO TUNER
OBSTACLE DETECTION SYSTEM FR RR RADAR OBSTACLE DETECTOR + RR CAMERA
LATERAL BLINDS SIDE BLINDS "ROW 2"
TRIM ADAPTATION LEATHER GEAR LEVER KNOB ILLUMINATED RR VIEW MIRROR
EQUALISER AMPLIFIER WITHOUT EQUALISER AMPLIFIER
RADIO FREQUENCY WESTERN EUROPE RADIO FREQUENCY
LOCKING CONTROL SIMPLE CENTRAL LOCKING
STEERING WHEEL LEATHER STEERING WHEEL 3 BRANCHES
DRIVER’S KNEE AIRBAG WITHOUT DRIVER’S KNEE AIRBAG
REAR VIDEO SCREEN WITHOUT REAR VIDEO SCREEN
AUDIO PACK AUXILIARY SOCKET 1 JACK PLUG + 2 USB
TELEMATIC UNIT INDEPENDENT TELEMATIC UNIT
Electrical
ALTERNATOR ISTT52
BATTERY BATTERY L3 760 VRLA2 EN AGM
STARTER MOTOR STARTER MOTOR CLASS 6+
SPECIAL LIGHTING AUTOMATIC LIGHTING + FRONT DAYTIME LIGHTS
CEN. LOCKING REM CONTROL FREQUENCY LOCKING REMOTE CONTROL FREQUENCY 433.92 MHZ HETERODYNE
LIGHTING OF LAMPS AUTOMATIC SWITCHING ON OF LIGHTS + AUTO SWITCHING
Component manufacturers
Miscellaneous
SPECIAL SPECIFICATION SPECIAL SERIES FRANCE
MODIF. DURING MODEL YEAR WITHOUT MINOR MODIFICATIONS
ATMOSPHERIC CONDITIONS NORMAL ATMOSPHERE
VIN PLATE EUROPEAN UNION CONSTRUCTOR’S PLATE + NRE
LABEL WITHOUT LABEL
RADIO HEADPHONE SOCKET TRIPLE ACCESSORIES SOCKET
TRAFFIC SIDE DRIVING ON THE RIGHT-HAND SIDE
SET OF KEYS 2 HF PLIP KEYS
EMERGENCY EQUIPMENT PUNCTURE REPAIR KIT
SURFACE CONDITIONS GOOD TERRAIN
ADDITIONAL TYPE APPROVAL PLATE W/O ADDIT HOMOLOGATION PLATE
SLAVE CONTROL UNIT BSI EVOLUTION
EMERGENCY WARNING TRIANGLE WITHOUT WARNING TRIANGLE
Ednic
x 5
Unread post by Ednic »
Would anyone be kind enough to do mine please?
2005 307SW
Thanks,
x 1056
Here you go
Características del vehículo
Línea de producto 307 REMODELADO
N° PV/PR 10616 89 2 0199
Fecha de Inicio de Garantía 20/12/2005
Número de serie del motor 10 DYTJ 4168686
NRE e2*2001/116*0235*02
Información general
TIPO DE PRODUCTO VEHICULO PARTICULAR
MARCA COMERCIAL/TIPO DE ÓRGANO PEUGEOT
LÍNEA DE PRODUCTO 307 REMODELADO
SILUETA BREAK TIEMPO LIBRE
ACABADO ALTO BASE
MOTOR DIESEL TURBO DW10BTED4 FAP
TRANSMISIÓN CVM6
TIPO DE PINTURA PINTURA METALIZADA VERNIE
COLOR DE CARROCERÍA EZR - PINTURA GRIS ALUMINIUM
TIPO DE REVESTIMIENTO INTERIOR CADENA Y TRAMA MINIKA + EFKA "NV"
COLOR DE GUARNECIDO "FX"
CAJA DE CAMBIOS (CARACTERÍSTICAS) CVM ML6 CL
MOTOR (TIPO) MOTOR TIPO EW/DW
MONOGRAMA COMPLEMENTARIO , DIVERSOS HDI (I ROJA)
MONOGRAMA SW
ACABADO ALTO BASE
DIRECCIÓN DIRECCION ASISTIDA VARIABLE
PAR DE TACÓMETRO SIN GRUPO TAQUIMETRO
Alimentación motor
ALIMENTACIÓN INYECCIÓN TURBO INTERCAMBIADOR DIRECTO
DETECTOR DE AGUA EN FILTRO DE GASOIL SIN DETECTOR DE AGUA EN FILTRO GASOIL
CÁRTER CILINDROS (MATERIAL) BLOQUE CILINDRO FUNDICION
CARBURANTE GASOIL CALIDAD DA/DE/DE+
DEPOLUCIÓN (MOTOR) ANTICONTAMINACIÓN MOTOR EURO 4
TOMA DE VELOCIDAD (INFORMACIONES DEL CAPTADOR) SIN TOMA DE VELOCIDADES
CILINDRADA 2000 CM3
CATALIZADOR CATALIZADOR 2 COMPONENTES FILTROS IMPR PLATINO
REFRIGERACIÓN DEL ACEITE MONTAJE INTERCAMBIADOR AGUA/ACEITE EN MOTOR
MOTOR DE REFRIGERACIÓN RADIADOR E 32 - 21 DM2 ALUMINIO SOLDADO
RECALENTAMIENTO DEL CIRCUITO DE GASES DE CÁRTER SIN CALENTADOR GASES
VARIACIÓN DE POTENCIA (MOTOR) POTENCIA ESTANDAR
VÁLVULAS POR CILINDRO 4
AUTODIAGNÓSTICO EOBD AUTODIAGNOSIS "EOBD" SIN ACELEROMETRO
DISPOSITIVO (ANTIPOLUCIÓN) RECICLAJE GASES ESCAPE "EGR"
DEPOLUCIÓN TÉCNICA DEL VEHÍCULO ANTIPOLUCION TECNICA VEHICULO L5
FILTRO DE PARTÍCULAS CON FILTRO DE PARTÍCULAS
VENTILADOR 1 VENTILADOR 2 VELOCIDADES 130W AERO
RECUPERACIÓN DE VAPORES DE GASOLINA SIN RECUPERACION VAPOR COMBUSTIBLE
VARIANTE ASOCIADA A LA INYECCIÓN MONTAJE SIEMENS
FILTRO DEPÓSITO FILTRO DEPOSITO INTERIOR
CAJA MARIPOSA (ADMISIÓN DE AIRE MOTOR) SIN CAJA MARIPOSA (ADMISION AIRE MOTOR)
PARADA Y MARCHA SIN STOP Y START
Caja de velocidades-Transmisión
TRANSMISIÓN CVM6
RELACIÓN DEL PAR CP 17 X 67
ESTILO DE RUEDA RUEDA EQUINOXE 16 PULGADAS
EMBRAGUE EMBRAGUE HIDRAULICO
TIPO DE CAJA DE CAMBIOS (HOMOLOGACIÓN) TIPO CV ML6CL
DIFERENCIAL (CAJA) DIFERENCIAL 86
LLANTA/NEUMÁTICO DIMENSIÓN MONTAJE NEUMATICO 16 PULGADAS
NEUMÁTICO (DIMENSIONES, TIPO) NEUMÁTICO 205/55 R16 91V NO REFORZADO
RUEDAS MOTRICES 2 RUEDAS MOTRICES
RUEDAS MONTADAS RUEDA 6,5 PULGADAS
RUEDA (TIPO) MONTAJE RUEDA ALEACION
INDICADOR DE PÉRDIDA DE PRESIÓN DE INFLADO SIN INDICADOR DE PERDIDA PRESION INFLADO
CAJA DE CAMBIOS TIPO ML6C
Suspensión Dirección Frenos
ANTIBLOQUEO ANTIBLOQUEO RUEDA
BARRA ESTABILIZADORA TRA BARRA ESTABILIZADORA TRASERA DIAM 30
ESTABILIZADOR DEL BARRA ESTABILIZADORA DELANTERA DIAM 23
FRENO TIPO DISCOS DELANTEROS VENTILADOS/DISCOS TRASEROS
REFRIGERACIÓN DEL ACEITE DE BOMBA DE DIRECCIÓN SIN REFRIGERACION ACEITE BOMBA DE DIRECCION
SUSPENSIÓN SUSPENSION CONVENCIONAL
SUSPENSIÓN (TIPO ARQUITECTURA) SUSPENSIÓN METÁLICA
CONTROL DINÁMICO DE ESTABILIDAD CONTROL DINAMICO DE ESTABILIDAD
AYUDA AL FRENADO DE URGENCIA CON AYUDA A LA FRENADA URGENCIA
VARIANTE ASOCIADA AL FRENO ESP BOSCH 8 0
DIRECCIÓN (FUNCIONAMIENTO) DIRECCION ELECTROHIDRAULICA ASISTIDA
SISTEMA PEDALES (TIPO) PEDALERA ESTANDAR
Carrocería-Equipamientos
ENGANCHE REMOLQUE SIN ENGANCHE REMOLQUE
BOCINAS BOCINA DOBLE
ANTENA ANTENA TECHO CORTA
DECORACIÓN (ADHESIVO) EMBELLECEDOR TRA SE PUERTA DEL + EMBELLECEDOR DEL DE PUERTA TRA
EMBELLECEDORES LAT.(ASPECTO) PROTECTORES LATERALES COLOR CARROCERIA
EMBELLECEDORES LATERALES (DIMENSIÓN) PROTECTORES LATERALES
EMBELLECEDOR DE RUEDA (ESTILO) TIPO APOLLO
LUZ DE RETROCESO CON 1 PILOTO DE MARCHA ATRAS
LUZ DE SEÑALIZACIÓN SIN LUCE DE SENALIZACION
COMPLEMENTO DE PROTECCIÓN (BAJO EL MOTOR) SIN PROTECCION COMPLEMENTARIA BAJO MOTOR
ANILLO DE AMARRE EXTERIOR (INSERTADO) SIN ANILLO DE AMARRE EXTERIOR
FUNCIÓN COMPLEMENTARIA DEL RETROVISOR EXT RETROVISOR EXTERIOR PLEGABLE MANUAL
EMBELLECEDOR DE LA SALIDA DE ESCAPE SIN EMBELLECEDOR SALIDA ESCAPE
INSONORIZACIÓN DEL LADO MOTOR INSONO CAPOT
LIMPIAPARABRISAS LIMPIAPARABRISAS CON CAPTOR DE LLUVIA
LIMPIALUNAS TRA CON LIMPIALUNAS TRASERO
LIMPIAFAROS SIN LIMPIAFAROS
LIMPIALUNAS TRA (FUNCIONAMIENTO) LIMPIALUNETA TRA INTERMITENTE AUTO MARCHA ATRÁS
OBTURADOR CARA DEL. SIN OBTURADOR FACHADA DELANTERA
CRISTAL DE TECHO CON LUNA DE TECHO
LUNA DE PORTÓN TRASERO LUNETA TRASERA FIJA
PARAGOLPES PARAGOLPES DEL+TRAS ESTANDAR COLOR CARROCERIA
GUARDABARROS (BABERO) SIN GUARDABARROS TRASERO
MATRÍCULA SIN PLACA DE MATRICULA
PORTA-MALETAS MONTAJE CON BARRAS DE TECHO
FARO ANTINIEBLA FAROS ANTINIEBLA
RETROVISOR EXT (LADO CONDUCTOR) RETROVISOR EXTERIOR CONDUCTOR MANDO ELECTRICO
RETROVISOR EXT (LADO PASAJERO) RETROVISOR EXTERIOR PASAJERO MANDO ELECTRICO
RUEDA DE REPUESTO RUEDA CHAPA PARA NEUMATICO ESTANDAR
ACCESORIOS EXTERIORES EMPUA EXT+EMBELLE PORTON ALU+RETRO EXT COLOR CAJA
RETROVISOR EXT. (RADIO LADO CONDUCTOR) ESPEJO ASFÉRICO RETRO EXT.
LAVALUNAS TRA LAVA-LUNAS TRASERO
TECHO CORREDIZO TECHO FIJO
EMBELLECEDOR DE PARAGOLPES EMBELLECEDOR DE PARAGOLPES COLOR CARROCERIA
LUNA (ASPECTO) TINTADA + SOBRETINTADA
LUNA CUSTODIA (TIPO) LUNA CUSTODIA FIJA
LUNAL (TIPO) PARABRISAS ACUSTICO SALVO SINGAPUR
PACK RADIO - INFORMACIÓN - COMUNICACIÓN RD4,SIN NAVEG,INDIC NIV C,SIN AMPLIF EQUALIZ
Equipamiento interior
ALARMA ANTIRROBO SIN ALARMA ANTIRROBO
REPOSACABEZAS TRA APOYACABEZAS TRASERO REGULABLE
REPOSACABEZAS DEL APOYACABEZA DELANTERO ARTICULADO
ASIENTO TRA 3 ASIENTOS TRASEROS SEPARADOS (1 DESLIZANTE)
ASIENTO SUPLEMENTARIO SIN ASIENTO SUPLEMENTARIO
REPOSABRAZOS ASIENTO TRA SIN REPOSABRAZOS ASIENTO TRA
MOLDURA DE PISO DE CARGA CON MOLDURA PISO CARGA
CUBRE-EQUIPAJES CON TAPA EQUIPAJES
CINTURÓN DE SEGURIDAD TRA CINTURON SEGURIDAD TRASERO 5 ENROLLABLES 3 PUNTOS
CINTURÓN DE SEGURIDAD DEL CINTURON PIROTECNICO CON ALARMA
CLIMA (T° AMBIENTE) PAISES TEMPLADOS
SEGURO DE PUERTAS PARA NIÑOS CONDENACION DE NIOS MANUAL TRASERA
GRADUACIÓN DE VELOCIDADES GRADUACIÓN VELOCIDADES EN KM/H
CUENTARREVOLUCIONES CUENTARREVOLUCIONES DE AGUJA
ACONDICIONAMIENTO DE RADIO ALIMENTA ANTENA RECEPT ALTAVOZ DEL TWT ALTAVOZ TRA
LADO DE CONDUCCIÓN (PUESTO DE CONDUCCIÓN) CONDUCCION A IZQUIERDAS
CALEFACCIÓN ADICIONAL CALEFACCION ADICIONAL AUTOMATICA
EQUIPAMIENTO DEL TABLERO DE INSTRUMENTOS PLANCHA DE ABORDO ESTANDAR + FACHADA GRIS LEON
VARIACIÓN DE REVESTIMIENTO EQUIPAMIENTO INTERIOR VOLANTE POMO FUELLE CUERO
LUCES INT. DIVERSAS 2 LZT 3 POSN+2 LECT MAPAS+2 LECTURA TR
BANDEJA DE TRABAJO CON BANDEJA DE TRABAJO
SITIO PARA OBJETOS BAJO ASIENTO 2 CAJONES DE ALOJAMIENTO BAJO ASIENTO
COMBINADO (CARACTERÍSTICAS) GRADUACION 220 KM/H 140 M/H FONDO NEGRO CERCO CROM
ANCLAJE DE LOS ASIENTOS DE NIÑOS SIN ANCLAJE CON ISOFIX DEL. Y TRAS.
ALTAVOZ 4 ALTAVOCES DEL (2 TW+2 DEL) + 2 ALTAVOCES TRASERO
MANDO DE AUTORRADIO MANDO AUTORRADIO A DISTANCIA SIN FUNCION CD
AISLAMIENTO (CORTINA, PARASOL LAT, TC) SIN CORTINA TRASERA
REALCE DEL ASIENTO DEL REALCE ASIENTO ACOMPAÑANTE REGLAJE PARALELO
MANDO DEL ASIENTO DEL CONDUCTOR ASIENTO CONDUCTOR MANDO MANUAL
MANDO DEL ASIENTO DEL PASAJERO MANDOS COJÍN DEL ASIENTO DEL ACOMPAÑANTE MANUAL
REGLAJE DEL ASIENTO DEL CONDUCTOR REGLAJE DEL ASIENTO DELANT CONDUCTOR CON RESPALADO INCLINABLE
REGLAJE DEL ASIENTO DEL PASAJERO REGLAJE ASIENTO ACOMPAÑANTE RESPALDO INCLINABLE
ABATIMIENTO ASIENTO DEL CONDUCTOR SIN ABATIMIENTO ASIENTO CONDUCTOR
ABATIMIENTO DEL ASIENTO DEL PASAJERO SIN ABATIMIENTO ASIENTO PASAJERO
REPOSABRAZOS DEL ASIENTO DEL APOYACODOS DELANTEROS CONDUCTOR Y PASAJERO
INDICADOR DE TEMPERATURA EXT. INDICADOR TEMPERATURA EXTERIOR
DISCO COMPACTO SIN MONTAJE DISCO COMPACTO
CAJA DE ALMACENAMIENTO SIN GUARDAOBJETOS
SISTEMA NAVEGACIÓN SIN SISTEMA DE NAVEGACION
LÁMPARAS DE FAROS LAMPARA HALOGENA
ELEVALUNAS TRA ELEVALUNAS TRASERO MANDO ELECTRICO SECUENCIAL
ELEVALUNAS DEL CONDUCTOR ELEVALUNAS CONDUCTOR MANDO ELECTRICO SECUENCIAL
ELEVALUNAS DEL PASAJERO ELEVALUNAS PASAJERO MANDO ELECTRICO SECUENCIAL
PANTALLA PANTALLA (RADIO+RELOJ, T°,CD)
ESPEJO DE CORTESÍA LADO CONDUCTOR + LADO PASAJERO OCULTABLES CON LUZ
REPOSAPIÉS REPOSAPIES CONDUCTOR
ACOLCHADO DE COJÍN DE ASIENTO ACOLCHADO ASIENTO DEL ESTANDAR
INDICADOR DE ACEITE RECEPTOR NIVEL ACEITE
MONTAJE DE REPOSACABEZAS TRA MONTAJE 3 APOYACABEZAS TRAS
TELA TÉRMICA ASIENTO NO TERMICO
AIRBAG LATERAL DELANTERO AIRBAG LATERAL TORAX+CORTINA
AIRBAG PASAJERO AIRBAG LADO PASAJERO
ELEVALUNAS ELÉCTRICO (FUNCIONAMIENTO) ANTIPINZAMIENTO CONDUCTOR + PASAJEROS AV/AR
ORDENADOR DE A BORDO CON ORDENADOR DE ABORDO
PACK DE EQUIPAMIENTO SIN PACK EQUIPAMIENTO
RETROVISOR EXT. (TÉRMICO) RETROVISOR EXTERIOR TERMICO
NEUTRALIZACIÓN DEL AIR-BAG NEUTRALIZACION MANUAL DE AIRBAG
MANDO INTERIOR PUERTA (ASPECTO) MANDO INTERIOR PUERTA ASPECTO GRIS LION
PISO TRA DE CARGA SIN PISO TRASERO CARGA
FARO CORRECTOR DE ALTURA PLATILLO REGLAJE ELECTRICO FAROS
PROTECCIÓN DE PUESTO DEL SIN PROTECCION CABINA DELANTERA
PARASOL DEL PARASOL CONDUCTOR + ACOMPAÑANTE SIN INSCRIPCIÓN
COLOCACIÓN (PUESTO DE CONDUCCIÓN) SIN ALOJAMIENTO CONSOLA DELANTERA DE TECHO
RECEPTOR DE RADIO SISTEMA AUDIO COMPACT DISC RDS "RD4"
REFRIGERACIÓN AIRE ACONDICIONADO AUTOMATICO REGULADO
REGULADOR DE VELOCIDADES REGULADOR Y LIMITADOR DE VELOCIDAD
REALCE ASIENTO DEL. CONDUCTOR REGLAJE ALTURA PARALELO CONDUCTOR
RETROVISOR INTERIOR RETROVISOR INTERIOR DÍA-NOCHE ELECTROCROMADO
PORTAOBJETOS (OTROS) UBICACIÓN ESTÁNDAR + PORTA MONEDAS
ALFOMBRILLA (ASPECTO) SIN ALFOMBRILLAS
AIRBAG CONDUCTOR AIRBAG LADO CONDUCTOR
PORTAOBJETOS VOLUMEN DE CARGA CON RED EN MALETERO
ALFOMBRA ALFOMBRILLA DE MOQUETA TUFTEE RASEE F470
TUNER RADIO MONO SINTONIZADOR RADIO
PROTECCIÓN INTERIOR SIN PROTECCION INTERIOR
INDICADOR DE TEMPERATURA DE AGUA INDICADOR DE TEMPERATURA DE AGUA TESTIGO + RECEPTOR GRADUADO
TESTIGO DE NIVEL DE LÍQUIDO DE REFRIGERACIÓN SIN TESTIGO NIVEL LIQUIDO REFRIG
DETECCIÓN DE OBSTÁCULO SIN DETECTOR DE OBSTACULOS
ADAPTACIÓN GUARNECIDO POMO PALANCA VELOCIDADES + FUELLE CUERO
ALFOMBRILLA SIN ALFOMBRILLAS
AMPLIFICADOR ECUALIZADOR SIN AMPLIFICADOR ECUALIZADOR
FRECUENCIA RADIO FRECUENCIA RADIO EUROPA OCCIDENTAL
MANDO DE BLOQUEO CIERRE SIMPLE CONDENA + AUTOMATICO
VOLANTE VOLANTE CUERO 3 BRAZOS
AIRBAG RODILLAS CONDUCTOR SIN AIRBAG DE RODILLA LADO CONDUCTOR
PANTALLA VIDEO TRA SIN PANTALLA VIDEO TRASERA
Electricidad
ALTERNADOR ALTERNADOR CLASE 15
BATERÍA BATERIA L3 450
MOTOR DE ARRANQUE MOTOR DE ARRANQUE CLASE 6+
LUCES ESPECIALES ENCENDIDO AUTOMATICO DE FAROS
MULTIPLEXADO MONTAJE MULTIPLEXADO CAN CAN
Marcas de equipamiento
Varios
CRITERIO DE VARIANTE, CLIENTELA CONCEPCIÓN INCITACION FISCAL ANTIPOLUCION L5
MODIFICACIÓN EN CURSO AM SIN MODIFICACIÓN MENOR
ATMÓSFERA ATMOSFERA NORMAL
ADAPTACIÓN DE ARMADO SIN ADAPTACION ARMAMENTO
PLACA DEL FABRICANTE PLACA CONSTRUCTOR UNION EUROPEA + NRE
ETIQUETA SIN ETIQUETA
TOMA DE ESCUCHA DE RADIO TOMA DE ACCESORIOS
LADO DE CIRCULACIÓN CIRCULACION A DERECHA
CHOQUES LATERALES PUERTA NO REFORZADA
JUEGOS DE LLAVES 1 LLAVE PLIP HF + 1 LLAVE PRINCIPAL UNICA
RODAJE BUENA CARRETERA
CONTROL DE LA VELOCIDAD SIN CONTROL VELOCIDAD
PLACA DE HOMOLOGACIÓN COMPLEMENTARIA SIN PLACA HOMOLOGACION COMPL
CAJA DE SERVICIO BSI COMM 2003
TRIÁNGULO DE PRE-SEÑALIZACIÓN SIN TRIANGULO PRESENALIZACION
Ednic
x 5
You're a gent sir.
Thank you.
owl
x 15
May I ask you please check this vin out for trim specs.? There is a misunderstanding between me and seller. He says this is shine pack, I say not it is written lounge. Since there is no lounge pack
VR7**************[VIN obfuscated, can be read by forum staff]
Thank you in advance
x 1056
owl wrote: 15 Oct 2025, 21:14 May I ask you please check this vin out for trim specs.? There is a misunderstanding between me and seller. He says this is shine pack, I say not it is written lounge. Since there is no lounge pack
C5 AIRCROSS (C84) 5-DOOR CROSS OVER 1.5 BlueHDi 130 (DV5RC Euro 6.2) STT TYPE 8-SPEED AUTOMATIC GEARBOX
Vehicle family C5 AIRCROSS (C84)
AS/RP N° 15787 CJ 2 0065
Warranty Start Date 11/03/2020
Engine serial number 10 Q4DL 0093903
OPB 00DZ
BER e2*2007/46*0642*03
P4A 9835917499
General information
COMMERCIAL MARQUE/COMPONENT TYPE CITROEN
VEHICLE FAMILY C5 AIRCROSS (C84)
SILHOUETTE 5-DOOR CROSS OVER
TRIM LEVEL UPPER MEDIUM
ENGINE DV5RC 96KW 1.5L DIESEL
TRANSMISSION STT TYPE 8-SPEED AUTOMATIC GEARBOX
PAINT TYPE PAINTED METALLIC EXT TRIM TYPE
BODY COLOUR EDZ - EMERALD CRYSTAL PAINT
INTERIOR TRIM TYPE NAPPA LEATHER "4H"
UPHOLSTERY COLOUR "FE"
GEARBOX (CHARACTERISTICS) ATNG8
DEFINITION TO FOLLOW INITIALE RANGE
ENGINE (TYPE) DV TYPE ENGINE
ROOF (EXT. ASPECT) BODY COLOUR ROOF
OTHER BADGE, " MISC. " WITHOUT FULLER BADGE
Fuel supply-Engine
FAN 2-SPEED FAN 140W AERO COMPACT DYNAMIC FLAP
STOP AND START WITH STOP AND START STARTER
FUEL SUPPLY DIRECT EXCHANGER TURBO INJECTION
EMISSIONS STANDARD (ENGINE) EURO 6.2 ENGINE EMISSION CONTROL
EXHAUST STANDARD EXHAUST
SPEED SENSOR SIGNAL FRONT WHEEL SENSOR NON-SIGN RR SIGNED
CAPACITY 1500 CM3
FUEL TANK NON-PRESSURISED FUEL TANK WITH LOCATING TAB
COOLING MOTOR RADIATOR EP28 28DM2 BRAZED ALUMINIUM
CRANKCASE GAS CIRCUIT HEATING WITH HEATER CASING GAS CIRCUIT
POWER VARIATION (ENGINE) ENGINE POWER 96 KW 300 NM
SPECIAL POWER TRAIN SOUND WITHOUT POWER TRAIN ACOUSTICS
EOBD SELF-DIAGNOSIS SYSTEM WITH "OBD" AUTO-DIAGNOSTICS
DEVICE (ANTIPOLLUTION) EXHAUST GAS RECYCING "EGR" + EXCHANGER
VEHICLE TECHNICAL DEPOLLUTION EURO 6.2 VEHICLE TECHNICAL EMISSION CONTROL
GEARBOX TYPE ATN8 TYPE GEARBOX
FINAL DRIVE RATIO FINAL DRIVE RATIO 15 X 58
WHEEL STYLE 19-INCH SAW ALLOY WHEEL
RIM/TYRE SIZE 19 INCH TYRE FIT
TYRE (SIZE, TYPE) 205/55 R19 97V TYRE
WHEEL (TYPE) ALLOY WHEEL ASSEMBLY 1
INFLATION PRESSURE LOSS INDICATOR INDIRECT DETECTION OF UNDER-INFLATION WITH LOCATION
BRAKE ASSOCIATED VARIANT ESP BOSCH 9.1
STEERING (OPERATION) LOW POWER DOUBLE PINION ELECTRIC POWER STEERING
PEDAL BRACKET (TYPE) SIMPLE STANDARD PEDAL BRACKET
REAR ANTI-ROLL BAR REAR ANTI-ROLL BAR STIFFNESS 30000 NM/RAD
STEERING COLUMN RETRACTABLE STEERING COLUMN
FRONT ANTI-ROLL BAR FR ANTI-ROLL BAR STIFFNESS 30000 NM/RAD
BRAKE TYPE VENTILATED FRONT DISCS/REAR DISCS
STEERING WHEEL ANGLE WITH STEERING ANGLE SENSOR
DYNAMIC STABILITY CONTROL SYSTEM ELECTRONIC STABILITY PROGRAM
Body fittings
HANDS FREE ACCESS AND STARTING FRONT ACCESS + BOOT + HANDS FREE STARTING
HORNS HORNS-HARMONY
SIDE MOULDINGS (TYPE) ALUMINIUM COLOUR SIDE PROTECTORS
SIDE MOULDINGS (DIMENSION) WITHOUT SIDE PROTECTOR, WITH CHROME SILL
WHEEL EMBELLISHER (STYLE) WITHOUT WHEEL TRIM
EXHAUST TAILPIPE WITHOUT EXHAUST TAIL PIPE
UNDERBODY SHIELD WITHOUT PROTECTION UNDER BODY
EXT. REARVIEW MIRROR COMP. FUNCTION DRIVER ELEC FOLDING+PASSENGER+DIODE+REVERSE +MEMORY
ENGINE BAY SOUNDPROOFING SOUNDPROOFING FOR BULKHEAD + WHEELARCH + POWER TRAIN
WINDSCREEN GLASS (TYPE) STANDARD WINDSCREEN GLASS
BUMPER BODY COLOUR FRONT BUMPER+GLOSS BLACK GRILLE/BODY COLOUR REAR BUMPER + TAILPIPE
LUGGAGE RACK MOUNTING WITH ROOF BARS
FRONT FOGLAMP FOG LAMPS WITH CORNERING LIGHT
PANORAMIC VISUAL AID WITH REAR PANORAMIC VISUAL ASSISTANCE VISIO PARK1
SPARE WHEEL SPACE-SAVING SPARE WHEEL
EXTERIOR ACCESSORIES BODY COLOUR EXTERIOR HANDLE
GLASS (APPEARANCE) TINTED + DARK-TINTED WINDOW GLASS
WINDOW (TYPE) ACOUSTIC LAMINATED WINDSCREEN + TOUGHENED REAR GLASS
Interior fittings
SEATING ASSOCIATED VARIANT VARIANT ASSOCIATED WITH HIGH SEAT POSITION
AUDIO PACK AUXILIARY SOCKET 2 USB PORTS
TELEMATIC UNIT INDEPENDENT TELEMATIC UNIT 3S
FRONT HEAD RESTRAINT 4-WAY ADJUSTABLE FRONT HEAD RESTRAINT
BLIND SPOT DETECTION ACTIVE BLIND SPOT MONITORING
REAR SEATBELT 2 PYRO RETRACTORD+ SEATBELT FASTENED TELL-TALE
CLIMATE (AMBIENT TEMP) COLD COUNTRIES
AIR CONDITIONING WITH AUTO RECIRCULATION HEATER MATRIX
CHILD LOCK MANUAL REAR CHILD LOCK
GEAR SELECTOR RAISED GEAR LEVER AT THE FLOOR + AT THE STEERING WHEEL
CONSOLE UPPER CONSOLE + STORAGE COMPARTMENT
MIRROR LINK WITH MIRROR LINK
MISC. INT. LAMPS LC FR/RR LEDS WITHOUT AMB LED WITH AMB LGT
INSTRUMENT PANEL (CHARACTERISTICS) DIGITAL INSTRUMENT PANEL 29 WARNING LAMPS
DOOR TRIM GLOSS BLACK DECOR DOOR TRIM
CHILD SEAT ANCHORING POINTS WITH CHILD SEAT MOUNTING WITH ISO FR AND RR
PROTECTIVE COVER WITHOUT PROTECTIVE BATTERY COVER
POLLEN FILTER WITH POLLEN FILTER + ACTIVATED CARBON
DRIVER SEAT CONTROL DRIVER’S SEAT MEMORY CONTROL
FRONT PASSENGER SEAT CONTROL MANUAL FRONT PASSENGER SEAT CONTROL
DRIVER SEAT ADJUSTMENT DRIVER’S SEAT TILTING BACK ELECPNE LUMBAR SUPPORT+MEMO
FRONT PASSENGER SEAT ADJUSTMENT ADJUSTMENT FRONT PASSENGER SEAT CUSHION RECLINING SEAT BACK
FRONT SEAT ARMREST CENTRAL ARMREST FLOCKED + PVC
TRAFFIC INFORMATION READER PREVENTION+TRAJECTORY CENTRING LPA
DISPLAY DGT8C SCREEN DISPLAY
CUSHION PADDING PADDING WITH PASSENGER DETECTION PAD
OIL GAUGE W/O OIL LEVEL INDICATOR
HEATING ELEMENT DRIVER + R1 PASSENGER HEATED SEAT
FRONT LATERAL AIRBAG FR CHEST/PELVIS SIDE AIRBAG+CURTAIN AIRBAG
FOOTWELL LIGHTING DRIVER + FR PASSENGER FOOTWELL LIGHTING
EQUIPMENT PACK W/O EQUIPMENT PACK
WIFI WITH WIFI
RADIO RECEIVER DIGITAL CONNECTED NAVIGATION
CRUISE CONTROL SPEED LIMITER ACC STOP AND GO REGULATOR
CARPET COVER BLACK MAT CONTRAST SURROUND+LASER ENGRAVING
LOAD SPACE STORAGE RETRACTABLE FLOOR STORAGE COMPARTMENT
REAR SEAT PADDING REAR PASSENGER DETECTION WITH PAD
TUNER RADIO DUAL RADIO TUNER
OBSTACLE DETECTION SYSTEM FRONT-REAR RADAR OBSTACLE SENSOR
LOCKING CONTROL NORMAL + AUTOMATIC LOCKING
STEERING WHEEL FULL GRAIN LEATHER FULL 3-SPOKE STEERING WHEEL
Electrical
LIGHTING OF LAMPS AUTOMATIC SWITCHING ON OF THE LIGHTS+AUTOMATIC SWITCHING
ALTERNATOR ALTERNATOR CLASS 18 180 AMP
HORNS HORNS-HARMONY
BATTERY BATTERY L3 760 70AH EFR 760 EN EF
STARTER MOTOR STTD STARTER
CEN. LOCKING REM CONTROL FREQUENCY 433.92 MHZ SUPER HETERODYNE
BATTERY CHARGER WITHOUT ON-BOARD CHARGER
MULTIPLEXING R3 ECO ELECTRICAL ARCHITECTURE
ELECTRIC VEHICLE CHARGING PLUG WITHOUT VEHICLE LOAD RECOGNITION
BATTERY CHARGE MEASUREMENT WITH BATTERY CHARGE MEASUREMENT
Miscellaneous
SPECIAL SPECIFICATION SOCIETE (OVSA)
CONDENSER (SPECIFICATIONS) CONDENSER 23,5DM2 THICKNESS 12
LABEL WITHOUT LABEL
AIR CONDITIONING PIPES IHX TECHNOLOGY AIR CONDITIONING PIPES
RADIO HEADPHONE SOCKET DOUBLE ACCESSORY SOCKET
SIDE IMPACTS REINFORCED SIDE IMPACT PROTECTORS
SET OF KEYS SET OF BADGE KEYS + BACK-UP KEY
DOOR SEAL FRONT DOOR FRONT SEAL
REFRIGERANT AIRCON FLUID 1234 YF
EMERGENCY EQUIPMENT W/O HELP EQUIPMENT
SPEED MONITORING WITHOUT SPEED CHECK
SLAVE CONTROL UNIT BSI + COM 2008 + POLY SOUND
owl
x 15
God bless you!
