Alternator bearing lifetime
Thunderbird
Unread post by Thunderbird »
Salut!
My Xantia 2.0HDi alternator bearing got in bad condition at 50Kmiles/4 years. Is this normal?
From watching the alternator after removal, I noticed a certain rusty on the mechanical connection point. Can this be related to the bearing problem?
Thunderbird
Jon
Unread post by Jon »
Sounds a bit unusual. The alternator on my ZX was still sound at 150,000 miles with no bearing noise at all!
x 1472
The alternator on my BX TD seized at 113k miles, but then it had been noisy ever since I got it at 66k, and when I checked at about 90k there was quite noticeable radial play in the alternator. I guess this was due to the belt being overtightened in the past.
NiSk
Unread post by NiSk »
The Mitsubishi 90 Amp alternator on my '93 XM TD 12 is still on it's original bearings at 530,000 km. However it is on it's third set of brushes.
//NiSk
Stuart McB
Unread post by Stuart McB »
Old ZX TD bearings packed up at 152k after water on to it. Took a small puddle a little too fast, well when I say puddle the wife reckons it was more like a brook.
