Notchy/ jerky steering
stu9
x 5
Unread post by stu9 »
On a 12 reg C5 X7 3.0 hdi it has 185000 so seen better days probably. I will try bleeding it but if no joy then it is probably a new rack.
To be honest though I got it fairly cheap because of high miles short mot so really don't know if I should just cut my losses with it or fix things.
It has had a few things fixed in the last 2 years by the previous owner but no proof.
It seemingly has a new battery so that shouldn't be the issue but will check the alternator etc later.
I was also reading the other post above about the wrong rack fitted etc. I don't think that is the case with this it is just probably worn.
But as I said i don't know what to do with the car in general.
x 8130
Re: Notchy/ jerky steering
You mentioned 'other post above' but this is the first post in the thread so did you mean to post elsewhere? :)
stu9
x 5
Sorry i meant to other guy with the same problem.
x 1939
Unread post by Paul-R »
It would be helpful to post a link to this other post or quote it.
stu9
x 5
x 1939
Which post on those 5 pages?
