307 AIRBAGS
backstep
307 AIRBAGS
HI,ANYONE KNOW IF AIRBAG MODULE HAS TO BE RESET WHEN NEW DASH AND AIRBAG+ PRETENSIONERS HAVE BEEN FITTED,AND MODULE, OR SHOULD EVERYTHING WORK OK.GETTING AIRBAG FAULT MESSAGE+LIGHT IS ON.THANKS.
- x 1056
PowerLee
If any part of the SRS system has been deployed, The control box will need to be replaced too.
Deploying the SRS systems also destroys the control box, You cant give a 100% guarantee the control box will work a second time, there are some mighty fine electronics in that control box & the car manufactures cant take any chances with being taken to court because a SRS system failed.
