Battery
Adam1984
Battery
Unread post by Adam1984 »
Hello.
So I did a battery test this morning on my CGP 2017, the voltage was 12.40, but when running went to to 14.30.
Would this battery start to cause electronic issues to appear on the car.
I don't know when the battery was installed, so think worth getting a new one?
wurlycorner
x 271
Re: Battery
Unread post by wurlycorner »
Those voltage readings are normal.
You’d need different test equipment to check the battery condition - can’t determine that on voltage alone.
What prompted you to test it? Is your car having problems?
Iain
CX DTR T2 Safari (silver)
Adam1984
Re: Battery
Hello,
Thank you for the reply. I ask only because am having various issues and electrical faults come up on the vehicle.
Am getting inspection today from a member off here.
The issues are Parking Sensor Fault (Intermittent) - dead centre front sensors going off on occasions.
Rain sensor fault.
Rear demist windscreen fault
Immobiliser fault (even though the car still starts perfect)
Thanks.
