Hi all
I have a ds3 2016 puretech UK, wiper motor needs changing but been advised i need to disconnect negative battery terminal first but when i look at the battery housing it looks like i have to remove the positive connection first before getting to negative can anyone help please
Car battery
- x 8119
Re: Car battery
The norm is to disconnect the negative first so that you cannot short the battery positive to earth with a spanner while removing it. That is the reason, however you can remove the +ve first as long as you take care not to short it to earth with your spanner. Once off just cover the exposed battery terminal with an insulating cover like a rattle can lid or similar to prevent shorting it by accident while you are working.
Moey79
Re: Car battery
Thank you was looking at my battery only was i can get to the negative is remove positive first then all the housing
