creaking at front
b21playa
creaking at front
Unread post by b21playa »
i can hear creaking when i take the car off the erb and when on full lock sometimes
any ideas
i thought it might be ball joints, and further light???
batwad
Unread post by batwad »
Dude, is this all still the same car? Why on Earth did you buy it? [}:)][;)]
x 1496
Had this on our ZX - needed a new rear wishbone bush on the front N/S - the old one was totally knackered. New bushes were about £20, but a new arm was only £33, and that came with a new ball joint as well.
Stuart McB
Unread post by Stuart McB »
The wifes Renault had this sound aswell. It was the Anti roll bar bushes. Replaced by the dealer. But still cheap the buy.
b21playa
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by batwad</i>
cuz i got it cheap
so far inc repairs it was cost me £150 and thats including the new ball joints i bought today
i will fit them and then find out if it sorts the problem
b21playa
replaced the ball joint today and its not that, the old one is still good, so theres £10 wasted
anyway i held the wheel at 9 and 3 and there was play but i have no idea where is it
any ideas?
snoble80
Unread post by snoble80 »
I had lots of movement and clonking on my car when holding the wheel there. It turned out to be the hole that the balljoint slots into on the hub had ovalised. This had been caused by the groove in the balljoint being worn or the bolt having thread where it goes through the groove on the balljoint, which gets depressed and allows the balljoint to move up and down.
Replacing the balljoint does nothing in this case and a new hub is required to fix the problem.
b21playa
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by snoble80</i>
does sound logical
rossd
Unread post by rossd »
On my 306 phase 1 it creaks going up and down kerbs, but the phase 2 I have driven does not. I have heard that it is body flex on the phase 1's causing this, and the phase 2's are much stiffer, having something like 1000 more spot welds when they were made. I'm not sure how true this is though. Its only very slight though, you can hardly hear it. Any louder than barely noticable would mean something else, rear beam bearing perhaps?
