Misfire maybe
Jonny1208
Misfire maybe
Unread post by Jonny1208 »
Good evening all ,
I have a problem with my 1998 Peugeot boxer 2.0 injection petrol .
Starts first time every time no problems. Revs no problem .
Go down the road and coughs and splutters until it gets warm , and this can take up to approximately 15 miles depending on the weather . After this it runs a dream .
Things I have changed so far . That I can think of 🤔😅
Coil x 2
Leads
Plugs x 3 times
TPS twice .
Air intake sensor
MAP sensor twice
Injectors
Exhaust sensor .
ECU temperature sensor 6 times .
Dash temperature sensor 3 times
New cam belt and water pump .
BREATHER VALVE .
Idle air control valve.
Control valve
Fuel pump relay .
Cam crankshaft sensor .
Exhaust.
Fuel filter twice .
Air filter twice
Any help would be appreciated . Thank you .
Next to try is the fuel pump
I have no air leaks .
Spark plugs are the right light brown colour .
I have just come back from North Wales today , runs beautifully when warm and that was a 600 round mile trip . Friday 29/08
x 8111
Re: Misfire maybe
Having replaced so much I think you should do a scan with a high end diagnostic kit to read the fault codes and see what is going on. :)
x 1460
Re: Misfire maybe
Unread post by xantia_v6 »
Being 1998 this may have an OBD diagnostic connector or may have a proprietary rectangular PP2000 connector?
Jonny1208
Re: Misfire maybe
Mickthemaverick . Thank you for your reply . It doesn’t have a obd port that is the main problem I am having .
Jonny1208
Re: Misfire maybe
Hi ,
What is a proprietary rectangular PP2000 connector ?
x 3306
Re: Misfire maybe
Might I suggest you run a Google search for "1998 Peugeot Boxer Diagnostics Port"? I did, and I found a few YouTube videos showing various locations. It is likely that your van has an OBD 1 port, which may need an adaptor to work with more recent diagnostic equipment.
Jonny1208
Re: Misfire maybe
Thank you . Cannot find a Peugeot one but found a fiat one which looks identical
