DPF fluid
Oveone 123+++
DPF fluid
Hi, newbie here. My 2010 407 has a warning that dpf fluid is low. I do not know if it is a bag or a tank, most seem to think a tank. I have been told to use an Eolys fluid or just a universal one. Can anyone advise please? I would appreciate any help. Thanks in advance, Phil.
- x 8086
Re: DPF fluid
If you post your VIN , which will be masked from public view, we may be able to confirm the fluid you need.
- x 1056
Re: DPF fluid
Pretty sure this car has a fillable tank.
Post the RP number from the tyre pressure label to confirm fluid type, 2010 will be right on the changeover point for the different fluids.
Oveone 123+++
Re: DPF fluid
Hi, not sure what an RP number is lol, sorry if I`m a bit dim on this. lol
Oveone 123+++
Re: DPF fluid
VIN VF3**************[VIN obfuscated, can be read by forum staff] thanks
- x 8086
Re: DPF fluid
Maybe attach a picture of your tyre pressure label on the door/pillar
Oveone 123+++
Re: DPF fluid
Hi, dont know how to upload photos, on bottom it says
12183CJ
10021
EZRC
0770002
720 EN
Is that what you mean? Thanks
12183CJ
10021
EZRC
0770002
720 EN
- x 5671
Re: DPF fluid
Ther is a guide to uloading photo's here
We have found that many taken with digital cameras and especially phones will appear to 'fall over', or turn turtle, usually when zoomed. Check before submitting by using the preview button and if they do then remove them and using an image viewer, rotate them to their proper orientation, or rotate 90° then return them and save, then re-upload.
PaulC5
- x 675
Re: DPF fluid
12183 comes back as 18th March 2010 in this calculator http://www.citroen-ds-id.com/gen/Gen_Organr.html
The CJ will be the factory (Rennes la Janais plant in France) and the paint code is EZRC
Oveone 123+++
Re: DPF fluid
Thank you everybody. So glad I joined, knowledgeable, friendly and so helpful.
- x 1067
Re: DPF fluid
And I've not even joined the conversation yet...thank you
Champion of Where's CitroJim
- x 8086
Re: DPF fluid
That's probably why we got the comment!!
- x 1067
Re: DPF fluid
