C3 Oil Filter
Gambit
x 9
C3 Oil Filter
Unread post by Gambit »
Having changed my oil filter today , Im not in she who must be obeyed's good books!
I just pumped 2-3 lt of oil all over the drive. Because I missed the fact the filter cover needs a hard push to start it screwing home. I must have got it cross threaded because id did it up to 25 Nm.
Who ever designed the filter access needs replacing, the only way I could see was to take 2 air ducts off and then take the top hose off the radiator, its still tight but you can just get it in with some persausion
Any body else got a better way?
x 8128
Re: C3 Oil Filter
I believe that is one of the real headaches with that engine, with any luck someone with more direct tknowledge of it will be along and maybe offer a work round :)
PaulC5
x 696
Re: C3 Oil Filter
Unread post by PaulC5 »
If the same as our 1.6 hdi Cactus I manage without having to remove a radiator hose but some things do need removing.
