Citroen Relay 2.2 injectors
ChrisD1981
Unread post by ChrisD1981 »
Hi everyone,
I'm new here and am hoping for some help.
I own a 57 plate Citroen Relay 2.2 hdi. I've replaced the injectors with remanufactured Denso from an online retailer (not ebay).
I've fitted the new injectors and had a friend code them. The problem he's having is that the engine management light won't go out. He's getting a message that the correction values are to high and can't complete the pilot learn.
If anyone can help I'll be hugely grateful 🙏
x 8151
Re: Citroen Relay 2.2 injectors
A read through this thread may give you some pointers. :) Also this video may be helpful:
x 1944
Unread post by Paul-R »
My first thought is did your friend know that the engine is numbered from the gearbox end? If not he will have got the coding wrong.
ChrisD1981
He coded them from pulley to gearbox so sounds like they're the wrong way round
ChrisD1981
So we've switched the injector codes round and they still won't learn. P1304 learning not performed permanent fault is the code we're getting
x 8151
Has your friend watched the video I posted?
ChrisD1981
Yeah he's tried both ways. As soon as he tries gearbox to pulley the recode fails. When he tries pulley to gearbox it gets half way through and then we get correction values to high and it fails
x 8151
Yes I appreciate he has coded both ways and made no progress, but has he watched the video and taken note of the various points about code length, injector type and in some cases the necessity to remap the ECU? :)
ChrisD1981
Yeah he has. He's a commercial mechanic so understood the video better than me. I also had my usual mechanic try and he kept getting the same issue
x 8151
OK, well I'm afraid I can't offer any further advice but hopefully another member with better knowledge will see your thread and help out. Good luck :)
ChrisD1981
Thanks for your help, it's appreciated 🙏
Steve Walsh
x 518
Unread post by Steve Walsh »
Worked on a 2.2 in a transit a few years ago , It took about a dozen attempts to get codes accepted, It would get part way through and fail. Eventually they where accepted and all was good
ChrisD1981
So it's finally sorted. Turns out that 2 of the injector codes were incorrect from the supplier. Only found out when we tried coding them individually instead of all at once. Codes supplied and everything coded.
Thanks for your help guys 👍
x 8151
Excellent well done we love it when a plan.......... :)
