peugeot 3008 hybrid4 v.2013
Mika
Unread post by Mika »
autoradiossa ongelma. gps ei toimi ja päivämäärä sekä aika sekoilee. Kuuleman mukaan ajan voi määrittää uudelleen gps laitteen päältä kytkemisen jälkeen. En ole vielä testannut. Päivityksen saa myös jostain firmware 2.6 jotain.
Linkkiä kaivataan sen saamiseksi!?
Entä karttapäivityksiä näin vanhaan autoon, onko niitä saatavilla ilman rahallista sijoitusta?
x 1938
Re: peugeot 3008 hybrid4 v.2013
Unread post by Paul-R »
Please post in English. Use a translation service if necessary.
Mika wrote: 13 Aug 2025, 18:54 car radio problem. gps does not work and date as well as time mixes. According to the hearing, the time can be redefined after switching off the gps device. I haven't tested yet. You can also get an update from some firmware 2.6 something.
A link is needed to get it!
What about map updates in such an old car, are they available without a financial investment?
Mika
Car radio problem. GPS not working and date and time are mixed up. The time can be reset after turning off the GPS device. I haven't tested it yet. You can also get an update from some firmware 2.6. A link is needed to get it! What about map updates for such an old car, are they available without financial investment?
x 1938
Are you sure it's 2.6? There's no 2.6 anything for the RT6 system.
