Peugeot 508 SW AT fluid
Umbrella_741
Unread post by Umbrella_741 »
Hello guys. Got recently my 508 SW (8E_) 2015 1.6 BlueHDi and about to change the AT fluid. In my Launch X431 scanner the gearbox identifies as BVA_AM6_AT6_UDS. After some research I found out that for this particular box it should be an AW-1 fluid (it is also indicated on filling screw on the top of gearbox), but not sure about viscosity. Older versions of TF-80-SC for EURO 4 vehicles require T4/JWS3309 fluid, which have higher viscosity. In my case, should it be ATF III or ATF VI version of AW-1? And I found two different part numbers of atf: 9730.AF and 9734.R7. Which one is closer to my car?
Thank you in advance.
Here is my VIN for a reference: VF3**************[VIN obfuscated, can be read by forum staff]
x 8052
Re: Peugeot 508 SW AT fluid
As we currently have no access to the parts database the best advice I can give is to suggest you contact Opie Oils to find out which fluid you need, this is a link to their website: https://www.opieoils.co.uk/c-1497-peugeot.aspx :)
x 1438
Unread post by xantia_v6 »
The simplest statement is:
GiveMeABreak wrote: 10 Mar 2024, 16:26 Depending on your vehicle's Euro Standard You'll need either:
JWS 3309 for Euro 4 Vehicles
JWS 3324 (Type AM6-2 / AM6-2 / AT6/ AT6-3) - equivalent to AW1 for Euro 5 or Euro 6 Vehicles.
Umbrella_741
Thank you guys for your replies :-D =D>
x 5645
mickthemaverick wrote: 30 Jul 2025, 21:00 As we currently have no access to the parts database the best advice I can give is to suggest you contact Opie Oils to find out which fluid you need, this is a link to their website: https://www.opieoils.co.uk/c-1497-peugeot.aspx :)
We used to have a member who worked at Opie Oils, not been seen for a long time though. His input may have been useful.
Umbrella_741
myglaren wrote: 30 Jul 2025, 22:09
Just contacted with OpieOils, now wait for a reply (lets see tomorrow morning).
LedZep
x 30
Unread post by LedZep »
I use this brand for years now and the guide they provide.
https://www.raxol.eu/en/oilfinder/
I think that this is the oil that you need.It has Viscosity on 100°C, 6.0 mm²/s .
https://www.raxol.eu/en/product/atf-super-s-6000/706/
Umbrella_741
LedZep wrote: 31 Jul 2025, 06:42 I use this company for years now and the guide they provide.
Good morning. Thank you for your reply mate.
Their website and oil guide look similar to "Addinol" (and from guideline it has to be Addinol XN 6 fluid)
https://www.addinol-shop.de/addinol-xn- ... fikationen
