Is my new NOX sensor working?
Dezbo
Unread post by Dezbo »
Hello,
I recently replaced the NOX sensor on my 2018 Peugeot Boxer 2.0 AdBlue HDI diesel. It only has the one. I disconnected the battery during the replacement and cleared the error after reconnecting (P2202). I haven't seen any further errors since --- but I'm not sure if the new NOX sensor is performing. I get the following counts. All counts seem to be increasing except the NOx Absorber which is 0. Should the count increase? Not sure how to confirm the new NOX sensor is speaking to the rest of the system? Any advice on checks is greatly appreciated. The new NOX sensor is a genuine replacement and supercedes the previous number.
OBD-II
ECU protocol: 7) ISO 15765-4 CAN (29 bit ID, 500 kbaud)
ECU address/CAN Id: 10
Calibration ID: 162488
In-use Performance Tracking for compression ignition engines:
OBD Monitoring Conditions Encountered Counts
: 472
Ignition Cycle Counter: 2850
NMHC Catalyst Monitor Completion Condition Counts: 256
NMHC Catalyst Monitor Conditions Encountered Counts: 60
NOx/SCR Catalyst Monitor Completion Condition Counts: 387
NOx/SCR Catalyst Monitor Conditions
Encountered Counts: 472
NOx Adsorber Monitor Completion Condition Counts: 0
NOx Adsorber Monitor Conditions Encountered Counts: 0
PM Filter Monitor Completion Condition Counts: 977
PM Filter Monitor Conditions Encountered Counts: 472
Exhaust Gas Sensor Monitor Completion
Condition Counts: 738
Exhaust Gas Sensor Monitor Conditions
Exhaust Gas Sensor Monitor Conditions Encountered Counts displays the number of times that the vehicle
has been operated in the specified exhaust gas sensor monitoring conditions (denominator).: 866
EGR and/or VVT Monitor Completion Condition Counts displays the number of times that all conditions
necessary to detect an EGR/VVT system malfunction have been encountered (numerator).: 472
EGR and/or VVT Monitor Conditions Encountered Counts displays the number of times that the vehicle has
been operated in the specified EGR/VVT system monitoring conditions (denominator).: 1375
Boost Pressure Monitor Completion Condition Counts displays the number of times that all conditions
necessary to detect a boost pressure system malfunction have been encountered (numerator).: 472
Fuel Monitor Completion Condition Counts: NaN
Fuel Monitor Conditions Encountered Counts: NaN
x 1938
Re: Is my new NOX sensor working?
Unread post by Paul-R »
Did you reinitialise the NOx system after fitting the new sensor? Just deleting any error codes won't be enough.
Dezbo
Hi.
No I didn't reinitialise the NOX system. I disconnected battery to reset the ECU only. What nneds to be done to reintialise the NOX system. I was told the new NOX sensor was plug and play --- but also hearing it should be calibrated?
x 1938
You will need a Diagbox or other high end diagnostic machine. From memory you go into the engine (also sometimes called injection) ECU and then into pack repair. It's there somewhere!
Dezbo
Thank you for info. If the new NOX sensor wasn't talking to the rest of the system, wouldn;t there ba a comunication error?
Just spoke to my local garage who wants £120 to do it plus an additional £40 for a token from Peugeot to connect the the vehicle. Does this sound right? Any one know anywhere in Cheshire who can do this who knows exactly what needs to be done.
x 1938
You don't need to connect to the dealer network to do this.
I'm just up the road in Wirral if that's any help? My Diagbox is currently out of action but my Xtool D8W should be able to do it. I reset the Denox system on our 308 last week with it.
Dezbo
How much do you charge? I had a mate try to connect his Autel MS906 Max - but he couldn't get it to connect so thinking Diagbox was the only route :(
x 1938
Dezbo wrote: 23 Jul 2025, 10:13How much do you charge? I had a mate try to connect his Autel MS906 Max - but he couldn't get it to connect so thinking Diagbox was the only route :(
No charge, just a donation to the forum.
Dezbo wrote: 23 Jul 2025, 10:13I had a mate try to connect his Autel MS906 Max - but he couldn't get it to connect so thinking Diagbox was the only route :(
Now you're making me worried! I'm still willing to give it a go if you are though?
Dezbo
Where abouts roughly are you. I'm south of Chester so may be a bit away?
x 1938
Pensby Thingwall area.
