In tank fuel pump
Mazzy7126
In tank fuel pump
Unread post by Mazzy7126 »
Hi can anyone confirm if the Citroën C4 Grand Picasso mk 2 2016 1.6 HDi / BlueHDi 115 1560cc 85KW 115HP has a in tank fuel pump and sender and if so the model number. Vin is VF7**************[VIN obfuscated, can be read by forum staff]
x 1938
Re: In tank fuel pump
Unread post by Paul-R »
Does the fuel system have a squeezy bulb to prime the fuel filter? If it does then it won't have an in-tank pump as well. Just a simple fuel level sender.
Mazzy7126
Thank you, I'll have a check, its my father's car so not sure but think it may have the 'squeezy bulb'
x 2336
Unread post by MattBLancs »
Just keep in mind the priming bulb on the 1.6 HDi is under the engine cover often so you'll have to lift that off.
x 1485
AFAIK all the blue HDis have an in tank pump.
CitROeNALD
x 10
Unread post by CitROeNALD »
I recently had a potential issue with the fuel pump/sender. From what I gleaned it seemed that the tank may have to be dropped to access it.
From what I could find out, there is no tank access from the cabin in the C4 Grand MK2.....which is ...wonderful....thank you Citroen....
Thankfully my issue resolved itself.
