This is a video I made four years ago on how to remove the door trim of the Grand Picasso.
There’s a part I couldn’t capture clearly in the video:
Even after removing the plastic clips, the door panel won’t come off easily.
That’s because it’s still held in place by a U-shaped steel wire clip at the circular area shown in the photo.
If you remove that wire clip, the panel will come off.
I've marked the location of the wire clip in the link below — please refer to it for guidance.
https://m.blog.naver.com/dezang/222488107600
Grand C4 Picasso II door panel Remove Vedeo
- x 8068
Re: Grand C4 Picasso II door panel Remove Vedeo
I'd make the same comment about wearing protective gloves when working with body panels as I made on your dash cam video.
mideos
Thanks you!
