C5 Aircross coolant
Steve Walsh
- x 518
C5 Aircross coolant
Hi
Does anyone know the total coolant capacity for a 2021 C5 Aircross. 1.5 Blue HDI DV5RC
Getting ready for a full service/timing belt and pump, I cant seem to find info anywhere
Steve
Steve
moizeau
- x 423
Re: C5 Aircross coolant
Steve, no idea, sorry. On a completely different note I see you have a Zeph11. Could you measure the width of the handlebars please. Mine seem too narrow, though the holes are correct for the switch gear. Thanks
Pete
Steve Walsh
- x 518
Hi Pete
I have Z900 Bars on mine, higher and wider. 81cm wide, The ones that came with the bike that I think are the originals are 70cm wide
Hope that helps
Steve
Hope that helps
Steve
moizeau
- x 423
Thanks very much, it helps a great deal. Mine are only 64ish not measuring the bar ends. Must have been off a 750 or even a 550. If you want to sell me your originals let me know.
Cheers Steve
Cheers Steve
Pete
- x 1072
I didn't think suicide rockets were allowed!! And not even french!!!!!!Ryan
Champion of Where's CitroJim
Steve Walsh
- x 518
You are welcome to them, I am near Nontron , not sure how far away you are, I don't have time to parcel them up and post.moizeau wrote: 01 Jul 2025, 18:37 Thanks very much, it helps a great deal. Mine are only 64ish not measuring the bar ends. Must have been off a 750 or even a 550. If you want to sell me your originals let me know.
Cheers Steve
OnlinePaulC5
- x 692
Why do you want to change the timing belt when only 4 years old, has the car done a lot of km ? If like our 308 with the same engine, the coolant should be checked at 4 years old but our dealer just replaced it.
Steve Walsh
- x 518
Just short of 120000km, got a few long trips coming up and wopuld never run till recommended change at 180000km, I will be doing full kit with waterpump so will be putting new coolant.PaulC5 wrote: 01 Jul 2025, 22:28 Why do you want to change the timing belt when only 4 years old, has the car done a lot of km ? If like our 308 with the same engine, the coolant should be checked at 4 years old but our dealer just replaced it.
I do it all myself so only parts to pay for
moizeau
- x 423
Thanks for the offer SteveSteve Walsh wrote: 01 Jul 2025, 21:27
I'm at Limoges airport 30 July in the morning. You are about an hour further south so not a bad detour.
Is this any good? If not I'll be there again on the 11 August.
Pete
Steve Walsh
- x 518
Away on 30th but 11th could be OK, I have a friend that lives 30 mins closer to Lim than me, I might be able to leave them there.moizeau wrote: 02 Jul 2025, 16:39Thanks for the offer SteveSteve Walsh wrote: 01 Jul 2025, 21:27
moizeau
- x 423
Steve Walsh
- x 518
Further to above post, if anyone needs the info, It took 5 litres after draining and waterpump change.
owl
- x 15
I am searching this info on the internet and other sources for 2 days. God bless you.Steve Walsh wrote: 18 Jul 2025, 10:45 Further to above post, if anyone needs the info, It took 5 litres after draining and waterpump change.
Mihael_M
- x 37
Double post, please delete.
Mihael_M
- x 37
An empty system holds 6 to 6.5 liters of antifreeze. But it is difficult to remove all the liquid, there is always about 2 liters left. It is preferable to flush the system with clean water. Garage mechanics won't do it, so it's a do-it-yourself option. I buy 3 liters of 100% antifreeze and first I pour in and then distilled water. There are procedures to remove all fluid from the system if compressed air is used.
