C5 Aircross coolant
Steve Walsh
x 518
C5 Aircross coolant
Unread post by Steve Walsh »
Hi
Does anyone know the total coolant capacity for a 2021 C5 Aircross. 1.5 Blue HDI DV5RC
Getting ready for a full service/timing belt and pump, I cant seem to find info anywhere
Steve
moizeau
x 423
Re: C5 Aircross coolant
Unread post by moizeau »
Steve, no idea, sorry. On a completely different note I see you have a Zeph11. Could you measure the width of the handlebars please. Mine seem too narrow, though the holes are correct for the switch gear. Thanks
Pete
Steve Walsh
x 518
Hi Pete
I have Z900 Bars on mine, higher and wider. 81cm wide, The ones that came with the bike that I think are the originals are 70cm wide
Hope that helps
Steve
moizeau
x 423
Thanks very much, it helps a great deal. Mine are only 64ish not measuring the bar ends. Must have been off a 750 or even a 550. If you want to sell me your originals let me know.
Cheers Steve
Pete
x 1077
Unread post by Rp0thejester »
:offtopic: :offtopic: :offtopic: :wtf: :wtf: I didn't think suicide rockets were allowed!! And not even french!!!!!!
Steve Walsh
x 518
moizeau wrote: 01 Jul 2025, 18:37 Thanks very much, it helps a great deal. Mine are only 64ish not measuring the bar ends. Must have been off a 750 or even a 550. If you want to sell me your originals let me know.
Cheers Steve
You are welcome to them, I am near Nontron , not sure how far away you are, I don't have time to parcel them up and post.
PaulC5
x 698
Unread post by PaulC5 »
Why do you want to change the timing belt when only 4 years old, has the car done a lot of km ? If like our 308 with the same engine, the coolant should be checked at 4 years old but our dealer just replaced it.
Steve Walsh
x 518
PaulC5 wrote: 01 Jul 2025, 22:28 Why do you want to change the timing belt when only 4 years old, has the car done a lot of km ? If like our 308 with the same engine, the coolant should be checked at 4 years old but our dealer just replaced it.
Just short of 120000km, got a few long trips coming up and wopuld never run till recommended change at 180000km, I will be doing full kit with waterpump so will be putting new coolant.
I do it all myself so only parts to pay for
moizeau
x 423
Steve Walsh wrote: 01 Jul 2025, 21:27
Thanks for the offer Steve
I'm at Limoges airport 30 July in the morning. You are about an hour further south so not a bad detour.
Is this any good? If not I'll be there again on the 11 August.
Pete
Steve Walsh
x 518
moizeau wrote: 02 Jul 2025, 16:39
Away on 30th but 11th could be OK, I have a friend that lives 30 mins closer to Lim than me, I might be able to leave them there.
moizeau
x 423
Whatever suits you
Pete
Steve Walsh
x 518
Further to above post, if anyone needs the info, It took 5 litres after draining and waterpump change.
owl
x 15
Unread post by owl »
Steve Walsh wrote: 18 Jul 2025, 10:45 Further to above post, if anyone needs the info, It took 5 litres after draining and waterpump change.
I am searching this info on the internet and other sources for 2 days. God bless you. 😅Thank you.
Mihael_M
x 37
Unread post by Mihael_M »
Double post, please delete.
Mihael_M
x 37
An empty system holds 6 to 6.5 liters of antifreeze. But it is difficult to remove all the liquid, there is always about 2 liters left. It is preferable to flush the system with clean water. Garage mechanics won't do it, so it's a do-it-yourself option. I buy 3 liters of 100% antifreeze and first I pour in and then distilled water. There are procedures to remove all fluid from the system if compressed air is used.
