2021 Renault Kadjar 1.3 engine makes a tapping noise at tickover
Brian C5
x 4
Unread post by Brian C5 »
I wonder if anyone can provide me with any advice on what might be causing a loud tapping noise on my 2021 Renault Kadjar 1.3 petrol engine at tickover. This engine is fitted to many Renaults, Dacias, Nissans and Mercedes and seems to have a good reputation for reliability (apart for the plastic thermostate housing breaking/leaking). I have a friend who has a 1.3 Dacia Duster which doesn't make this type of noise. I have read the high pressure fuel pump can make a noise but it seems nearer the timing chain end. The car has only coverd 8.5K miles and has always been well serviced with renault.
It sounds as as if a tappet needs adjusted but i am aware it won't be this as its fitted with hydraulic adjusters.
Any advice would be appreciated.
Thanks in advance
x 8126
Re: 2021 Renault Kadjar 1.3 engine makes a tapping noise at tickover
Hi Brian
This is the sort of thing that is almost impossible to advise on without actually hearing the noise. If you could make a video of it and link it here someone may be able to suggest the problem.
Brian C5
x 4
Thanks for the reply. Is it possible to tell me how to attach a video? Thanks
x 1939
Unread post by Paul-R »
The forum doesn't permit uploading of videos directly but if you upload it to YouTube and then post the link here that will do the job.
