DS3 Cabriolet Roof is stuck half way open
BilW
DS3 Cabriolet Roof stuck
Unread post by BilW »
Hi, my 2018 DS3 Cabriolet Roof is stuck half way open!
Fuses seem OK in boot but had to replace a couple of weeks ago. Motor for roof got really hot and now doesn't work at all. Thinking I could need new Folding Roof Motors but can't seem to find these online anywhere.
Anyone got any suggestions? - Hoping it doesn't rain any time soon!
x 2007
Re: DS3 Cabriolet Roof is stuck half way open
Unread post by Stickyfinger »
This may show a lot of information about how it works etc.......
x 8167
Re: DS3 Cabriolet Roof stuck
Check in your handbook because I would have thought there will be an emergency manual closing method in the event of electrical failure? :)
x 8167
I found this solution to manually close the roof on a mechanics advice site: :)
Dear customer,
I fully understand the frustration of having the roof of your Citroën DS3 Cabriolet stuck half open, especially when there are no previous signs of failure or warnings on the dashboard. Before attempting any manual intervention, I recommend you perform a basic system reset: disconnect the negative terminal of the battery for at least 20 minutes, as in some cases this is enough for the electrical system of the roof to reset and return to normal operation. If this does not work, there is a manual procedure to close the roof, although it is not always documented by the manufacturer. To do this, you will need to access the trunk and remove the cover of the compartment where the roof mechanism is housed; this is usually located behind the interior panels. Once exposed, locate the roof motor, which usually has a hex or Torx-type slot designed to allow manual locking in the event of electrical failure. Using a suitable tool (such as an Allen or Torx wrench), you will need to turn this mechanism clockwise calmly and without forcing, until the roof is completely closed. Next, be sure to properly lock the front roof latches into the windshield frame to ensure that it is sealed. It is a process that can be somewhat time consuming and require some force, but it is safe if done with patience. Avoid forcing the roof from the outside or attempting to move it by hand, as you could damage the rail system or hydraulic mechanism.
Good luck :-D
x 1083
Unread post by Rp0thejester »
Motor hot after fuse replacement.... That's where I would start looking. If you weren't driving a Citroen I'd call in the seagulls.....
x 1481
Unread post by xantia_v6 »
I have merged and tidied up the 2 topics
x 1481
It is possible that the fuses blew and the motor is hot because the roof mechanism is mechanically jammed.
x 2007
If it is like the Pluriel it will be dirty cables/gear unit.
People oil them, which attracts more dirt...........which then clogs the gear unit with a paste/dirt mix and fills the cable "teeth"
kmousu
New User
Unread post by kmousu »
Does anyone have sunroof schemantics or design plans please. My roof is stuck and I think that it is dirt related but I do not know how to clean the cables etc. Is it possible to easily remove the motors or will the whole thing fall apart?
x 8167
What year and engine is your car? :)
x 8167
These are the diagrams on my 2012 copy of Servicebox if they are correct for your car: :)
DS3 - 0120 08 970202A - TOP TOP CONTROL.pdf
Copied from Servicebox backup
(80.27 KiB) Downloaded 104 times
DS3 - 0120 08 970201A - TOP TOP CONTROL.pdf
(181.6 KiB) Downloaded 101 times
DS3 - 0120 07 746880A - SUNROOF RETRACTABLE.pdf
(149.89 KiB) Downloaded 96 times
DS3 - 0120 07 746801A - SUNROOF FRAME - MOTOREDUCER.pdf
(135.48 KiB) Downloaded 108 times
