oil preference
john79
oil preference
looking at changing the oil in my 1.6 hdi berlingo it's a 2019 van , oil spec says total ineo first 0w30 , anyone else use this or an alternative to the same spec? thanks
- x 1072
Re: oil preference
Having worked in a garage we used the same oil for every vehicle. There's no way you can store all the different types. There was a post about oil a few years ago showing a graph, try searching for it.
Champion of Where's CitroJim
PaulC5
- x 693
Re: oil preference
Our Cactus uses the same oil and I get the Total oil at a reasonable price via ebay. There may be other brands that are suitable but I find it easiest to use the one Citroen recommend. I get the oil filter from a Citroen dealer so I know it is right, plus the sump plug washers are relatively cheap from them.
john79
Re: oil preference
this is what im thinking , garage's must just use a generic oil type , looking at opie oils web site they would need 20+ drum's of oil for different types of vehicles etc , Make's me wonder if my vehicle has actually got the correct oil in it or notRp0thejester wrote: 14 Jun 2025, 21:23 Having worked in a garage we used the same oil for every vehicle. There's no way you can store all the different types. There was a post about oil a few years ago showing a graph, try searching for it.
PaulC5
- x 693
Re: oil preference
If you went to a Citroen dealer they have a limited number of engine types so you would expect them to not need lots of different oil drums. It is possible a non dealer garage servicing all sorts of makes might use other brands of oils or the same brand/spec for all their services. Our dealer service receipts give the oil type/spec used on them so if they have used something different and there is an engine problem they might get found out.
Steve Walsh
- x 518
Re: oil preference
- x 1489
Re: oil preference
Shoving any old oil in a modern engine is a bad idea. I rather suspect this is the cause of many of the early welt belt failures. The OP's car will be a 1.5 in fact, with the under spec cam chain in the head, so the correct oil is important, and it certainly needs to be a DPF specific oil. The cost differential is marginal really if you shop around. Having said that, the youtubers LR Time swear by 10W40 in the Ford V6 diesel (which is also in some PSA cars) rather then recommended 10W30 as the thinner oil tends to lead to early main bearing failure.
- x 1995
