Citroen C3 2008 AC fan not working
Croata11
Unread post by Croata11 »
AC fan inside Citroen C3 not working.
Is there some miracle worker that has the drawing if the fan circuit so I can troubleshoot it?
VIN VF7**************[VIN obfuscated, can be read by forum staff]
Many thanks!!!
ozvtr
x 251
Re: Citroen C3 2008 AC fan not working
Unread post by ozvtr »
Do you have automatic AC or manual AC?
In an automatic AC it tends to be the speed controller.
In manual it tends to be the resistor or a burnt out connector on the back of the control panel.
Croata11
ozvtr wrote: 16 May 2025, 01:35 Do you have automatic AC or manual AC?
It's got a display from which AC is controlled.
There is a Valeo module that I assume controlls speed. PCB with transistor and a big cooler.
ozvtr
x 251
Yes they have 2 green electrical plugs.
It's common for these to fail. If you know how to solder, you can replace the transistor that fails. There are a few videos on YouTube. Otherwise you can buy Chinese copies from Ebay and ETC. They are not that expensive.
Croata11
ozvtr wrote: 17 May 2025, 09:13 Yes they have 2 green electrical plugs.
That's the one that failed, it's confirmed, I bypassed it last night aand got the blower working. Thanks
