AC fan inside Citroen C3 not working.
Is there some miracle worker that has the drawing if the fan circuit so I can troubleshoot it?
VIN VF7**************[VIN obfuscated, can be read by forum staff]
Many thanks!!!
Citroen C3 2008 AC fan not working
ozvtr
- x 234
Re: Citroen C3 2008 AC fan not working
Do you have automatic AC or manual AC?
In an automatic AC it tends to be the speed controller.
In manual it tends to be the resistor or a burnt out connector on the back of the control panel.
Croata11
It's got a display from which AC is controlled.ozvtr wrote: 16 May 2025, 01:35 Do you have automatic AC or manual AC?
There is a Valeo module that I assume controlls speed. PCB with transistor and a big cooler.
ozvtr
- x 234
Yes they have 2 green electrical plugs.
It's common for these to fail. If you know how to solder, you can replace the transistor that fails. There are a few videos on YouTube. Otherwise you can buy Chinese copies from Ebay and ETC. They are not that expensive.
Croata11
That's the one that failed, it's confirmed, I bypassed it last night aand got the blower working. Thanksozvtr wrote: 17 May 2025, 09:13 Yes they have 2 green electrical plugs.
