Clutch temperature high
DenisS
Unread post by DenisS »
Hello everyone.
I bought a Peugeot 5008 in 2021 1,2 (131) 6 st. Manual transmission.
I have a “clutch temp high, limit use of pedal” warning appearing, but only when using 6th gear? It does not generate any error codes. I think this warning is generated if clutch slip is detected.
I've read the forum, but I haven't found a solution. Maybe someone will tell you how to solve this problem.
PaulC5
x 688
Re: Clutch temperature high
Unread post by PaulC5 »
Something to read but not a solution viewtopic.php?t=74251
DenisS
I've read it, but there's no solution in this conversation.
