I have a 1999 306 1.8 XS, the car didn't come with an alarm and I want to get one fitted will i be able to get one fitted so that it links with my current r/c/l and key fob? Also any recommendations and prices?
Cheers
EZ
Alarm Systems
PowerLee
Hi
If you want an alarm that uses the original remotes you are a bit stuck.
Go for a cat 2 - 1 upgrade.
You car already has a Thatcham cat 2 imobiliser fitted at the factory & a 2-1 upgrade will upgrade your cars security to cat 1.
Some alarms have there own fobs & some use the original fobs.
Avoid the Peugeot alarm systems at all costs because they are rubbish and you can get a lot better for less money.
A cat 1 will have battery back up & either ultra sonic or microwave sensors for the cabin.
A cat 1 wont go off if the cars hit.
Find a VISB car alarm shop & have a chat with them.
Dont walk into Halfords!!!!
woody-som
Peter D
Although it is convenient to have one fob it is not where as secure. The single fob if duplicated or scanned during use, yes even the IR ones the car open and the alarm is turned off. I prefer to use one fob to cancel the alarm and one to open and start the car. This also has the advantage of a panic/attack button and tear off alarm fob you can press if your car is hijacked and the car shuts down after 30 seconds. However if you do fit a locking link unit between the larm and the car only use the Lock and disconnect the UNlock so only your Car Fob will open the car. Regards Peter
PowerLee
- x 1053
ezee_duzit
PowerLee
PowerLee
