Alarm Systems
ezee_duzit
Alarm Systems
Unread post by ezee_duzit »
I have a 1999 306 1.8 XS, the car didn't come with an alarm and I want to get one fitted will i be able to get one fitted so that it links with my current r/c/l and key fob? Also any recommendations and prices?
Cheers
EZ
PowerLee
Unread post by PowerLee »
Hi
If you want an alarm that uses the original remotes you are a bit stuck.
Go for a cat 2 - 1 upgrade.
You car already has a Thatcham cat 2 imobiliser fitted at the factory & a 2-1 upgrade will upgrade your cars security to cat 1.
Some alarms have there own fobs & some use the original fobs.
Avoid the Peugeot alarm systems at all costs because they are rubbish and you can get a lot better for less money.
A cat 1 will have battery back up & either ultra sonic or microwave sensors for the cabin.
A cat 1 wont go off if the cars hit.
Find a VISB car alarm shop & have a chat with them.
Dont walk into Halfords!!!!
woody-som
Unread post by woody-som »
I thought about this myself, and done some research into it.
i found that microscan do an alarm that will trigger using the existing central locking, and you can get a DIY kit for £80(ish) or if you want a Thatcham approved system, then add another £100 for someone to fit the same system.
Peter D
Unread post by Peter D »
Although it is convenient to have one fob it is not where as secure. The single fob if duplicated or scanned during use, yes even the IR ones the car open and the alarm is turned off. I prefer to use one fob to cancel the alarm and one to open and start the car. This also has the advantage of a panic/attack button and tear off alarm fob you can press if your car is hijacked and the car shuts down after 30 seconds. However if you do fit a locking link unit between the larm and the car only use the Lock and disconnect the UNlock so only your Car Fob will open the car. Regards Peter
PowerLee
A thatcham alarm system will have rolling code & anti scan & anti grab remotes so the same code is never repeated & the system will never accept the same remote code twice.
A code grabber or scanner is useless to car thieves on these!
x 1053
Unread post by wheeler »
Cobra & Meta both do systems that can work off the original plip.
ezee_duzit
I know it wan't recommended but I've picked up the Defender upgrade dirt cheap @ £10 brand new, how easy is this to fit or is it best to get it professionally installed?
Cheers
EZ
PowerLee
Hi
If its the full upgrade system it just plugs into the Peugeot wiring already fitted to your car.
Have a friendly word down your Peugeot dealer, Take the car & alarm down with you & ask them very nicely & they might even give you the wiring diagram.
PowerLee
Hi
Any more Defenders upgrades going dirt cheap?
A mates after an alarm for his 406, It already has the Keypad imobiliser.
