DTC U1213 y C1320
tomas2001
DTC U1213 y C1320
Unread post by tomas2001 »
Hi, I have a Citroen DS3, and I got codes C1320 and C1320. I replaced the battery because it needed replacing, and I thought it would solve the problem, but it didn't. Can anyone help me?
Djandree
x 38
Re: DTC U1213 y C1320
Unread post by Djandree »
Hi. by the look of it the fault code C1320 on a Citroen DS3 indicates a problem with the front left wheel speed sensor (Internet search). Have you got the ABS and ESP warning light on? The issue is likely a fault with the sensor itself, its wiring, or a short circuit.
tomas2001
Yes, I have the ABS, ESP, service and low tire lights on.
tomas2001
Sorry, I forgot to mention that I also have the code U1213
Djandree
x 38
have a look here viewtopic.php?t=73696
tomas2001
Based on what I've seen, they're focusing more on steering. I'll check the ABS sensor and wiring. Will it recognize an alternative sensor?
Djandree
x 38
Yes. But must meet the criteria. I was replacing 2 rear one id ds4 in my fiends car. Bought it on Amazon))))
check here: https://catcar.info/citroen/?lang=en
