timing belt c3 picasso 1.4 vti
vituk369
Unread post by vituk369 »
Hello everyone,
My c3 picasso has now reached 82000 miles. What is the timing belt recommendation in your country?
Thanks,
Filippp
PaulC5
x 689
Re: timing belt c3 picasso 1.4 vti
Unread post by PaulC5 »
The petrol vti engines have a timing chain and not a belt. The chains do wear though and the first signs might be a loss of performance or the engine light coming on with fault codes for the timing not being right - this was the case on a C3 we had at about 50k miles.
leithant
x 9
Unread post by leithant »
PaulC5 wrote: 21 Apr 2025, 20:52 - this was the case on a C3 we had at about 50k miles.
Only 50K!!! That's not good.
06 Citroen C5 Estate 2.2 Hdi Auto
95 Peugeot 306 S16
95 Silver Xantia VSX - now deceased :-(
vituk369
Does your car have the same engine as mine?
I found very different indications online. Some say 10 years, some say 100000 miles!
x 1938
Unread post by Paul-R »
100,000 miles (or more - up to 120,000) or 10 years, whichever comes first, is the standard service interval for most belts.
Note - belts not chains. And it specifically excludes the Puretech wet belt petrol engines.
vituk369
Thank you
Michel
Unread post by Michel »
PaulC5 wrote: 21 Apr 2025, 20:52 The petrol vti engines have a timing chain and not a belt. The chains do wear though and the first signs might be a loss of performance or the engine light coming on with fault codes for the timing not being right - this was the case on a C3 we had at about 50k miles.
Yes. Mine did this, then the timing chain broke and wrecked the engine about a minute later. I think it was on about 85k when that happened, always well maintained.
PaulC5
x 689
Our C3 was a 2010 with the 1.4 vti petrol engine.
Michel
PaulC5 wrote: 22 Apr 2025, 14:01 Our C3 was a 2010 with the 1.4 vti petrol engine.
Mine too.
