Hello everyone,
My c3 picasso has now reached 82000 miles. What is the timing belt recommendation in your country?
Thanks,
Filippp
timing belt c3 picasso 1.4 vti
PaulC5
- x 691
Re: timing belt c3 picasso 1.4 vti
The petrol vti engines have a timing chain and not a belt. The chains do wear though and the first signs might be a loss of performance or the engine light coming on with fault codes for the timing not being right - this was the case on a C3 we had at about 50k miles.
leithant
- x 9
Only 50K!!! That's not good.
06 Citroen C5 Estate 2.2 Hdi Auto
95 Peugeot 306 S16
95 Silver Xantia VSX - now deceased
95 Peugeot 306 S16
vituk369
Does your car have the same engine as mine?
I found very different indications online. Some say 10 years, some say 100000 miles!
- x 1939
100,000 miles (or more - up to 120,000) or 10 years, whichever comes first, is the standard service interval for most belts.
Note - belts not chains. And it specifically excludes the Puretech wet belt petrol engines.
Michel
Yes. Mine did this, then the timing chain broke and wrecked the engine about a minute later. I think it was on about 85k when that happened, always well maintained.PaulC5 wrote: 21 Apr 2025, 20:52 The petrol vti engines have a timing chain and not a belt. The chains do wear though and the first signs might be a loss of performance or the engine light coming on with fault codes for the timing not being right - this was the case on a C3 we had at about 50k miles.
PaulC5
- x 691
Our C3 was a 2010 with the 1.4 vti petrol engine.
