My o6 failed on simple things but the hydraulic pipe may be a downfall.
Can you still get parts for this?
Offside Front Suspension pipe leaking (5.3.5 (c))
.The garage thay did the MOT hadn't seen a c5 before!! So even the hydraulic pipe may be an issue.
Is this a tricky job for non specialist or does anyone know of a specialist in East Scotland.
Any advice on any of this appreciated. I'm just north of Dundee
MOT FAIL
Repair immediately (major defects):
Nearside Rear Stop lamp(s) not working (4.3.1 (a) (ii))
Rear Rear fog lamp not working (4.5.1 (a) (ii))
Offside Front Headlamp insecure (4.1.1 (c))
Nearside Front Headlamp insecure (4.1.1 (c))
Rear Brake disc significantly and obviously worn nearside and offside (1.1.14 (a) (i))
Rear Service brake excessively fluctuating (1.2.1 (e))
ADVISORIES
Monitor and repair if necessary (advisories):
Brake fluid close to minimum mark (1.1.10 (d) (ii))
Offside Front Brake disc worn, pitted or scored, but not seriously weakened (1.1.14 (a) (ii))
Nearside Front Anti-roll bar linkage ball joint has slight play (5.3.4 (a) (i))
Offside Brake pipe corroded, covered in grease or other material front to rear (1.1.11 (c))
Offside Front Play in steering rack inner joint(s)
Power steering pipe/hose slightly corroded (2.1.5 (g) (i))
Offside Front Suspension arm ball joint has slight play (5.3.4 (a) (i))
Nearside Front Suspension arm ball joint has slight play (5.3.4 (a) (i))
Nearside Front Shock absorbers has light misting of oil (5.3.2 (b))
MOT fail
Huskyxantia
- x 908
Re: MOT fail
C5 (X7) Leaking Pipe front right - French Car Forum
viewtopic.php?t=63151
Husky.
