DS5 update Sat Nav
Rob112
x 10
DS5 update Sat Nav
Unread post by Rob112 »
Hi
How do you update the built in sat nav ?
I get the car on Monday so not sure how up-to-date the sat nav is
Tia
Rob
Citroen DS5
Citroen Berlingo lwb van
x 1938
Re: DS5 update Sat Nav
Unread post by Paul-R »
What year is the car?
Rob112
x 10
It's a 2012
Citroen DS5
Rob112
x 10
Anyone?
Citroen DS5
x 1938
Don't know DS5s and was hoping someone else would know. Can you post a photo of the unit with something on the screen? That may help as I think you may have an RT6 or SMEGx unit.
Rob112
x 10
I get the car tomorrow will post tomorrow
Ty
Rob
Citroen DS5
Rob112
x 10
This is my sat nav any idea
Citroen DS5
x 1938
The photo doesn't show the unit switched on or anything on the screen to help identification but I'm pretty sure that's an eMyway/RT6 unit. Any chance of some photos of the various screens when switched?
Rob112
x 10
OK ta ill take pics tomorrow
Citroen DS5
Rob112
x 10
Here are some pics of the system turned on
Citroen DS5
x 8087
Hi Rob,
I found this link which you can get the updates from but I have only done an older C5 which simply involved putting the new maps disc into the DVD drive and it loaded up automatically so I can't help with how to do it as this is a download that you will need to transfer to your system. The site may have an instruction sheet to go with the update download. :-D
https://citroen.navigation.com/product/ ... enEMEA/GBP
Rob112
x 10
Hi Ty for the reply.
From more research it seems on a USB sick which I assume insert under the arm rest
Citroen DS5
x 1938
Yes, it's an RT6. I'm out at the moment but when I get home I'll send you a PM about updates.
Rob112
x 10
Paul ty
Citroen DS5
x 1938
PM sent regarding maps.
The link that Mick posted is the official update. I note that it says "The minimum software version required to use this product is 2.86". The instructions to check your software version say to give a long press to the "setup" button and the help menu will show up. Then select "device description" and then "software." This is how it's done on my C5 X7 but I don't see a "setup" button in your screenshot. If it's definitely there try a long press on some of the other buttons such as the thing that looks like two pages of writing that's one of the segments in the large round button. Then work your way round some other buttons!
