Alarm Sounds when Locking Citroen C4 Grand Picasso Exclusiv BlueHDi
Christos
x 3
Unread post by Christos »
I have an issue where the alarm sounds when I lock my Citroen C4 Grand Picasso Exclusiv BlueHDi.
If I unlock the vehicle with the alarm sounding, it stops and relocks itself a few minutes later.
The issue started when the battery went flat.
I have tried re-pairing the key by following the procedure and passing the key out of the window, etc. but without success.
Any ideas.
Christos
x 3
Re: Alarm Sounds when Locking Citroen C4 Grand Picasso Exclusiv BlueHDi
Looking at other posts here, it seems I might need a replacement siren module (part 9677756080).
Does that seem correct?
Do I need to recode anything, or is it simply plug and play?
x 1488
I've seen this reported quite a few times after a battery change - but never seen an actual resolution - ideally it needs to go on a diag computer to see what is triggering the alarm. Normally there is a delay period before it arms, so not sure why this changes after a battery change.
Christos
x 3
It sounds immediately I lock the car, but stops when I unlock it. The car relpcks itself a few moments later and the alarm doesn't sound.
The dealer is charging over £120 just to diagnose the fault.
x 8121
Hi Christos,
If you have a look at the map it may have a member close by who can assist with diagnosis. If there is send them a private message and be prepared to wait for a response as some members do not come on the forum very regularly. Good luck! :-D
https://www.google.com/maps/d/viewer?ms ... J2FqLQ&z=6
Christos
x 3
I have been advised that it TSB D6AW0157Q0 applies - £150 for the dealer to do a BSI update
I can't find the TSB online - is this something that members here have access to?
PaulC5
x 683
Unread post by PaulC5 »
If it needs a BSI update then I suspect you will need the dealer to do it.
Aving030303
New User
Unread post by Aving030303 »
Help me my alarm its not working, everything not working. My handle before its working with sensor. But now everything not working. Im using the key manually.
