Peugeot Partner B9 factory towbar wire diagram.
iggz
Unread post by iggz »
Hello.
My towbar electronics was ripped off.
I have the factory towbar + electronics module and I need to know how to connect wires from the tow electronics to the 13-pin socket.
Can anyone help?
x 1056
Re: Peugeot Partner B9 factory towbar wire diagram.
Unread post by wheeler »
Not sure if this will work but the towbar fitting instructions should be attached.
[The extension zip has been deactivated and can no longer be displayed.]
iggz
Hello.
Many thanks for that, seems to be very close. I am missing two wire colors, the brown and the pink, but maybe those are part of the harness and not the connector? i will check.
Thanks!
iggz
What the heck are those C and D references???
x 1056
I would guess they are for a little microswitch that detects when a trailer is connected so it can cut off the read fog lamps on the car & adjust ESP.
Looks like the pink wire is meant to connect to D
