2.2 HDi engine making screeching noise
Hugh The Boatman
Unread post by Hugh The Boatman »
I've had this Relay van for nearly a year and it started making this screeching noise, only when in gear, yesterday.
Any suggestions as to the cause, please?
TIA HTB
Site won't let me upload small mp4 file :-(
x 1499
Re: 2.2 HDi engine making screeching noise
Welcome
You will need to put it on Youtube or something and then link to it.
Does it make the noise as soon as you put it in gear, or only when rolling? In all gears?
Hugh The Boatman
Thanks, RichardW.
I've only got a 15 sec video, now uploaded to
I believe it starts as soon as it is put in gear, but not 100% sure as I haven't driven it myself in this condition.
x 1499
Sounds like a stone stuck behind a disc, but you need to confirm if it only does it when rolling.
wurlycorner
x 271
Unread post by wurlycorner »
Agree with Richard on that diagnosis.
Iain
CX DTR T2 Safari (silver)
Hugh The Boatman
The other driver said the van was fine for the first few miles, starting from cold, but the noise got worse and changing gear was nigh impossible.
wurlycorner
x 271
Changing gear impossible as in, the gear lever wouldn’t move/it wouldn’t go into gear? Or could change gear because as soon as you put the clutch in the car slowed down so quickly you needed to drop back down a gear again?
Iain
Hugh The Boatman
It's the first one, Iain. "the gear lever wouldn’t move/it wouldn’t go into gear"
PaulC5
x 717
Unread post by PaulC5 »
Is there any oil in the gear box ? How many miles has it done, is the clutch worn out ?
x 1481
Unread post by xantia_v6 »
It sounds to me like the clutch release bearing has collapsed.
wurlycorner
x 271
Yep kind of agree with that diagnosis also, based on the extra information about gears - although normally the screeching noise wouldn’t change with vehicle speed? It would be constant as soon as the clutch pedal is depressed and get worse with engine revs increasing?
Iain
