Hello! Citroen jumpy 1998 1.9 td. What is my Bosch fuel pump called
Jumpyer 98
Unread post by Jumpyer 98 »
Hello! I have a pretty nice almost rustfree Citroen jumpy from 1998 it has the 1.9 td with a Bosch mechanic fuel pump.
The bad thing is that is leaking, so i have to order and replace sealings.
To order the right sealings i have to know which pump it is.
Anyway the number plate on the front of the pump are impossible to read...
I hope there is someone that know what identification number or what my Bosch pump is called?
Thank you
x 8391
Re: Hello! Citroen jumpy 1998 1.9 td. What is my Bosch fuel pump called
It's almost certainly a Bosch VP20 or AS3. Both look (and are) very similar, the AS3 differing in having electronically controlled timing.
Pop up a photo of the pump and I can confirm. In any case, seal kits are the same for the VP20 and AS3.
A little on how to do the job can be found here:
https://www.eastment.net/boschpump1.htm
The biggest PITA by far is de-armouring the pump!
